i took it to a shop and they told me cly4misfire,and i needed wires and plugs. so got them and put them on and still have same code. so they said try a new coil. i did and still the same thing. the truck seems to run okay until i get about 3000rpms at idle then it seens to miss a lot. dont think i ever had it that high of rpms before so dont know if that is normal or not. but my light is still on.
it is a 2003 ranger with a 3.0l ,4wheel drive edge.
i have checked firing order several times found several different firing orders.
front front front
3 4 3 6 3 5
2 6 2 5 2 6
1 5 1 4 1 4
i used the first one which was the order it was in before i did anything.
does anyone have any ideas what i am missing to get the cel off.
thank you for any help
disconnecting the battery did the trick thank you antony 25 for all your help.i learned something today so guest it was not a bad day after all. thank you again
