Need new Muffler Bearings...
Old Jul 30, 2001 | 07:38 AM
Ryan356's Avatar
Ryan356
My muffler bearings are pretty noisy. Does anyone know where I can get some new performance ones?
Old Jul 30, 2001 | 10:10 AM
whomrig's Avatar
whomrig
I am sure any muffler shop that specializes in muffler bearings can do this.....heh heh
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 30, 2001 | 11:12 AM
jwtaylor's Avatar
jwtaylor
Go to your local hardware store, they should be found beside the sky hooks. If not check and see if they are near the board straighteners. Good luck.
Old Jul 30, 2001 | 11:57 AM
seebeew's Avatar
seebeew
I beleive its in the boating section next to the cans of waterline... Hope this helps...
-Chris
Big Red Ticking 92 F150
Tick,Tick,Tick,Tick,Tick,Tick,Tick,Tick
Old Jul 31, 2001 | 12:03 AM
1ole4d's Avatar
1ole4d
[font size="1" color="#FF0000"]LAST EDITED ON 31-Jul-01 AT 01:05 AM (EST)[/font][p]ROFL....no comment. Someone PLEASE tell me he's just joking....
Old Jul 31, 2001 | 12:14 AM
85351ho's Avatar
85351ho
go to autozome. they are in isle 3 next to the woodstretchers and vw beetle radiators and right under plug wires for a 99 psd
1985 F-150/351Ho/c6/4wd~94,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt (250 axles and spings)
37 inch boggers
Old Jul 31, 2001 | 04:58 PM
72stepside's Avatar
72stepside
I saw some in a brick mason's truck right next to the brick stretcher (yes, I fell for that) !!!!
Chris
72 F-100 Stepside
300 cid w/ Hedman Hedders
Pacer 264P 16" wheels
Old Jul 31, 2001 | 07:54 PM
Rosati's Avatar
Rosati
I think your all wrong. I went out in the garage and looked behind my glass welder, under the bod of grid squares, opened the safe with my left handed crecent wrench and found my book on rare auto parts and it says that muffler bearings are no longer used on cars manufactured after the year 1683.
Check out this site http://www.kalecoauto.com/
Krosati
Visit my homepage at ClubFTE
http://www.clubfte.com/users/krosati/
Old Aug 1, 2001 | 12:32 AM
85351ho's Avatar
85351ho
i need some help, i cant seem to find the firing order on my friends 89 f-250 with a 7.3, we changed the plug wires and plugs, but messed up
37 inch boggers
Old Aug 2, 2001 | 06:57 AM
TallPaul's Avatar
TallPaul
The muffler bearings on my Wife's Aerostar were shot. I could tell because the muffler would rotate on the pipe but was noisy. The bearings were so bad we had to replace the whole system. Also had a lot of trouble with the motor a couple years ago. Turned out to be a bad widget. All is well now.
Old Aug 2, 2001 | 06:20 PM
crazy_goodolboy's Avatar
crazy_goodolboy
A rattle I thought was bad muffler bearings one time was actually caused by just being too low on turn signal fluid. I filled it up to the proper 72 gallons and saved my rotator splint for another 100000 kms. I've got to go change the air in my tires, be back later.......
Old Aug 2, 2001 | 07:57 PM
Ford79's Avatar
Ford79
Change the air in your tires? I was always told to ROTATE the air in my tires.
Old Aug 2, 2001 | 08:38 PM
Steve_Uzi's Avatar
Steve_Uzi
Also check for File #13, it has information on Muffler Bearings... Also its next to the Aisle that has the new chain for Honda 4x4 ATVs...
And if your radio isn't getting all the stations, goto Radio Shack or similar store and get some Frequency Grease, and rub it on your Antenna.....
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old Aug 3, 2001 | 03:43 PM
hpflowman's Avatar
hpflowman
hey crazy dont forget to change your summer air in your tires for winter air before winter sets in.has anyone seen my metric cresent wrench?
Old Aug 7, 2001 | 12:04 AM
yblock's Avatar
yblock
Navy Surplus has everything you need. One of the most common causes of muffler bearing failure is lose of relative bearing grease, the only way to apply the grease is by reconnecting the fallopian tubes. You can get the tubeing at any auto parts store or you can get it by the reel at a surplus store. And by the way you can save a few bucks by getting a light bulb repair kit instead of buying new headlights.
