Fuel pressure check
Old Feb 1, 2009 | 03:39 PM
nakoakai's Avatar
nakoakai
Fuel pressure check
Pulled the plug off the engine mounted fuel filter to check for pressure no fuel spillage. Opened the cap found no fuel in the filter. Checked for elect. power to the fuel pump and its 10.9 to 11.0 volts is the pump bad in the HFCM?
Old Feb 1, 2009 | 03:47 PM
bismic's Avatar
bismic
It could be a bad pump. Could also be a plugged primary filter or air leaking into the lines / filter housings.
Old Feb 1, 2009 | 07:07 PM
Sarge261's Avatar
Sarge261
Can you hear the pump run when you key it on
Old Feb 3, 2009 | 12:21 PM
nakoakai's Avatar
nakoakai
Turn key on no sound from the fuel pump. Picked up new HFCM will check for pump operation prior to installation.
Old Feb 3, 2009 | 01:14 PM
UGA33's Avatar
UGA33
If you dont mind me asking, how much did you pay for a new HFCM?
Old Feb 3, 2009 | 09:59 PM
nakoakai's Avatar
nakoakai
New HFCM from Ford cost me $340.00 but that was the problem. The truck runs like a champ now.
Old Feb 4, 2009 | 11:02 AM
UGA33's Avatar
UGA33
I was expecting that thing to cost a little more. Huh. Glad you got the issue cleared up
