Shift Point
Old Feb 1, 2009 | 02:03 PM
eprn1n2's Avatar
eprn1n2
Shift Point
As a new operator of a diesel truck I have a question about the shift point. I've noticed that when you stand on it it shifts up toward 3000 rpm. Wouldn't it be better for it to shift in its power band of 2000 rpm? Is there a control box that will let you shift at that point? I read about the Gear Vendors gear splitter and read that they reduce the shift point to 2000 rpm.
Old Feb 1, 2009 | 11:50 PM
adambomb's Avatar
adambomb
i don't really know what your asking exactly but our trucks make their most HP @3000 and torque @2000 (using round even numbers). so to me sounds like when you "stand on your tuck" it will rev out to the 3000 rmps easily.
Old Feb 2, 2009 | 09:33 AM
Wyatt66f100's Avatar
Wyatt66f100
short shifting doesnt help in a diesel truck because it makes better torque in low rpms. if you shift before ideal conditions it wont pull as much because your not letting it get to its optimal rpm area for torque.
Old Feb 2, 2009 | 10:19 AM
eprn1n2's Avatar
eprn1n2
But as I understand it the optimal rpm for torque is 2000 rpm. I would think the best shift point under load would be at most 2300 rpm bringing the rpm back to 1700 or so then up to 2300 again before the next shift. Diesels are not high reving engines and torque drops off very quickly past 2000 rpm.
Old Feb 2, 2009 | 10:44 AM
duffman77's Avatar
duffman77
These engines make 325hp at 3300RPM. Torque is just a rotational force, HP is a measure of how fast you can deliver that force and hence your ability to tow heavy loads at high speeds.
Old Feb 2, 2009 | 11:05 AM
eprn1n2's Avatar
eprn1n2
But torque is what pulls. Thats why a semi truck has 12 forward gears. It keeps the engine in its pulling band of peak torque. Torque vs HP has always given me problems. My understanding is that torque is the actual force the engine is generating whereas HP is a function of torque applied through gearing. HP relates more to speed than pulling power.
Old Feb 2, 2009 | 11:07 AM
dchamberlain's Avatar
dchamberlain
I have the 6.0L with a manual transmission, so I get to control the RPM's that I pull at. From experience I can say it makes it's best power over 2000 RPM's. Using your example, if a shift drops the RPM's to 1700, you'd be at a serious power disadvantage.
When I'm shifting for most power, like when I'm hauling the camper up the mountain pass, I'm shifting so that at the finish of the shift I'm around 2200 RPM. Which puts my shift around 3000 RPM. When I'm in a steep enough grade, I just leave it in 4 and can run up to 65 or so without any problem.
Old Feb 2, 2009 | 11:32 AM
UGA33's Avatar
UGA33
Let me try and simplify this. Torque gets you going, HP keeps you going. The 6.0L isnt what you would consider your normal diesel. It is a high revving diesel. Factory redline is 3600 rpms, yet the motor is capable of turning 4000-4200 rpms (someone chime in with the exact number, I cant remember!) Mine with an automatic pulls much better over 2000 rpms. If safety wasnt an issue, i would tow at 75-80 mph because that puts the truck right in its sweet spot, 2100-2200 rpms.
Old Feb 2, 2009 | 12:48 PM
dchamberlain
Tach redline on my truck, and the PCM rev limiter is 4200 RPM.
Old Feb 2, 2009 | 01:00 PM
spence13e's Avatar
spence13e
if it shifts at 2000, you drop to ~1300 or so, and that's not enough to do anything with. i've never needed to wrap it much more than 26 or 2700 pulling, but that's because i've done all my pulling out on the flats. but things do move much faster with the extra revs. especially when empty. and they sound so nice @ 3300 rpm...
Old Feb 2, 2009 | 01:29 PM
UGA33's Avatar
UGA33
Agreed. When i tow, i just let her eat. Whatever she wants to do she does. She usually revs to 2600-2800 rpms. I dont push it when it has heavy weight in tow, but it has always got the load moving well without me having to rev it over 3000 rpms.
Old Feb 2, 2009 | 01:46 PM
brickie's Avatar
brickie
My experience is the same unless i've got a hot tune having fun then the tach goes just about to the red
Old Feb 2, 2009 | 03:54 PM
eprn1n2's Avatar
eprn1n2
Let's say for grins that they came up with a new transmission for the 6.0 that would hold a set rpm. Your primary power gauge would then be boost but what rpm would you run it at?
