Riding Rough 50-60 mph
Old Feb 1, 2009 | 09:54 AM
BAJI26's Avatar
BAJI26
When I travel between 50 - 60 mph the Ex rides kinda rough but from about 65mpg and up its like in a aeroplane with out the air pockets... just smooth and quiet.
What could be causing this?!
Thanks!
Old Feb 1, 2009 | 10:44 AM
tesseesman's Avatar
tesseesman
could be tire imbalance , what shakes? steering wheel? rear of truck?
jeff
Old Feb 1, 2009 | 11:33 AM
BAJI26's Avatar
BAJI26
It doesn't shake it just feels like it I'm riding on a gravel road... I'm gonna drive it today and I'll see if I can be abit more accurate with the description.
Old Feb 1, 2009 | 11:38 AM
tesseesman's Avatar
tesseesman
ok let me know what you come up with and maybe i can help
Old Feb 1, 2009 | 11:32 PM
BAJI26's Avatar
BAJI26
Its just in the steering, it feels like I can feel the texture of the road.
Old Feb 2, 2009 | 05:01 AM
tesseesman's Avatar
tesseesman
ok providing all your suspension/steering components are tight, try having frt wheels balanced , usualy when wheel/tire is out of balance the shake occurs between 50-60 mph
Old Feb 2, 2009 | 05:24 AM
katiesdad7's Avatar
katiesdad7
That also applies to a persons age. :-)
Old Feb 2, 2009 | 07:38 AM
Bodaddio's Avatar
Bodaddio
I have been having the same problem, but I get a flashing and blinking battery light also.
For me it feels like I am driving on a rutty dirt road in a front wheel drive car.
I took the truck to Auto Zone, my charging system all checked out and there are no codes.
So far, I have upgraded my battery and most of my ground cables. I have 2 ga. wire for the positive side and the ground to the frame. I used the same wires, for the other grounds.
I also pulled all the COP's to look for wear.
I still get the flashing battery light, just no where near as much. But the rough "feeling" is gone.
Not sure if that helps. I met a guy that does side work here that used to be a Ford Mechanic; he said I can come by sometime and we can hook it up to his scanner, so we will see.
If you would like I can keep you up to date on what I have going on.
Cheers,
Shawn
Old Feb 2, 2009 | 08:31 AM
gt5-33's Avatar
gt5-33
Tires
I have the same issue with my Excursion. I have taken it to a dealer and they said my tires cannot be 'Road Force Balanced". I think my tires are the problem and will replace them in the future. It happens most of the time after the Excursion has been sitting for two weeks. I believe the tires get out of round from sitting. It gets better after driving for awhile.
Old Feb 2, 2009 | 08:39 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Get flat spots on the tires. I hadn't experienced that since I was a kid taking tobacco to the warehouse. Dads truck (a 1966 ford f100) had bias ply tires on it and it would get flat spots in them while sitting there unloading. Unless you got a load on your truck, you really shouldn't be getting them in my opinion.
Old Feb 2, 2009 | 08:46 AM
gt5-33's Avatar
gt5-33
Agree
CampSpringsJohn, I agree with your comments. I purchased the vehicle with the tires on it. Mid range priced tires which have much of the tread left. Indentations in the side walls which is a workmanship problem causes tires to get out of round.
Old Feb 2, 2009 | 11:02 PM
BAJI26's Avatar
BAJI26
I purchased them tires back in Nov. GoodYear SA 185/76/16, got an alignment at the same time.
Old Feb 2, 2009 | 11:13 PM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Ok now I see why you have rough ride
Old Feb 3, 2009 | 08:02 AM
cbradford's Avatar
cbradford
When is the last time the tire were rotated.
Old Feb 3, 2009 | 01:09 PM
BAJI26's Avatar
BAJI26
not since I installed them in NOV.
