Resistor mod for E4od tranny....
Old Jan 31, 2009 | 11:56 PM
Jrock909's Avatar
Jrock909
Guys how come my overdrive light is flashing when using a 50ohm - 10 watt resistor when I install it between the EPC line, which is the white/yellow wire on pin 12 of the trans connector..... My F-150 is a 92, so is there anything in the trans that needs updated to use this mod?
Old Feb 1, 2009 | 10:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That circuit is monitored by the PCM. It can read the resistance of the circuit, so it knows that there is about 54 ohms instead of the 4 ohms it's looking for. The flashing OD light is letting you know that there is something wrong with that circuit.
Old Feb 1, 2009 | 02:39 PM
Jrock909's Avatar
Jrock909
Right so I can't use that resistor, it's the resistor that B&M gives you in their kit. Just thought I might use it for some added kick when the truck shifts.....
mvedepo
6.7L Power Stroke Diesel
321
Mar 11, 2019 08:27 PM
Rocketattack
Apr 25, 2016 09:00 PM
ihcc104
Apr 16, 2016 08:13 PM
tshrager
Apr 13, 2011 09:38 AM
Epd444
May 27, 2009 01:27 PM
