Added Safety Chains to Trailer
Old Jan 31, 2009 | 10:43 PM
jomac11's Avatar
jomac11
Well I decided to go ahead and add safety chains to my goosneck stock trailer. I bought some 5/16" chain at the local hardware store (4800lb rated, break rating somewhere aroudn 15k). I drilled holes thru the channel in the neck of the trailer and used 7/16 grade 8 bolts to attach the chains. Hope I never have to use them, but glad they are there now...
Old Feb 1, 2009 | 07:11 PM
Steina's Avatar
Steina
CO River Rat
Yeah, they're cheap insurance. Don't forget to cross 'em........
Steve
Old Feb 1, 2009 | 08:40 PM
senix's Avatar
senix
also be sure that you have your breakaway cable attached for the brakes too. Good insurance for sure.
Old Feb 1, 2009 | 09:28 PM
jomac11's Avatar
jomac11
Yep, they fit well crossed...have another post about getting the breakaway system up and running...
Old Feb 3, 2009 | 02:28 PM
grafekie's Avatar
grafekie
You don't have to cross gooseneck chains :P The cross is to support the tongue of a tagalong trailer to prevent the hitch from digging into the road and snapping the chains.
Good for you for adding chains!! So many people neglect them.
Old Feb 3, 2009 | 02:33 PM
jomac11's Avatar
jomac11
I figure if the trailer comes loose, its going backwards. If the chains are crossed it will make them just a little shorter and it will stop the trailer from moving much. I'm sure we could debate the reasons to do one or the other, but I'll keep crossing mine...
Old Feb 3, 2009 | 03:00 PM
rambuck's Avatar
rambuck
Great job man! They are a great thing to have on ANY trailer. All the trailers we use at the farm, they have safety equipment like the chains that we cross. I've had a couple trailers break off but didn't go flying because the chains held them up a bit.
Old Feb 4, 2009 | 06:51 AM
petey shoes's Avatar
petey shoes
10 points for adding chains! hope you NEVER need them.
Old Feb 4, 2009 | 08:18 AM
jomac11's Avatar
jomac11
No kidding, those nice shiny new chains sure look pretty
Old Feb 4, 2009 | 08:24 AM
grafekie's Avatar
grafekie
Why don't you just size the chains the correct length? :P Crossing is very important for tagalong trailers but has no real use on goosenecks. But the important part is HAVING chains, and you now have those
I added pretty chains on my friend's carhauler which we borrow all the time, and three months later when she noticed them she was quite pleased. A little work and $20 goes a looong way to adding safety.
Old Feb 4, 2009 | 09:13 AM
jomac11's Avatar
jomac11
Because the right length for my truck and the right length for my dad's truck are not the same thing, because the mounting points are different. I made them long enough for his truck, and I have to twist them on mine, didn't have much choice.
Old Feb 4, 2009 | 09:51 AM
billnuke1's Avatar
billnuke1
I pull a 21' TT w/my 2000 Exc'. I had rusty old different sized chains that came w the trailer. Looked like crap! Bought a set of heavy duty plastic coated coiled cables. No more ugly ol' chains! I also run my brake control and electrical hook up through them. Nice and neat!
Old Feb 4, 2009 | 11:18 AM
grafekie's Avatar
grafekie
Most cables aren't strong enough... I used grade 88 chains (9000lbs working weight, 20k breaking, the strongest I could find) and grade 8 bolts. Most of the cables are only strong enough for lightweight trailers. I don't like to tangle my cables and such up with the chains, I want each part to be independant from the other. I don't want a hitch failure to cause the chains to pull out the emergency brake pin, causing the brakes to activate before the trailer is fully seperated from the truck. That will cause the chains to fail even if they were functioning properly. The brakes are meant to be activated only when the chains fail and cause the trailer to become fully independant. Be sure things are free enough to do their job in the event of an emergency. Pretty is nice, but pretty is as pretty does!
Old Feb 4, 2009 | 04:40 PM
billnuke1's Avatar
billnuke1
Well said and noted!
Old Feb 4, 2009 | 04:58 PM
Steina's Avatar
Steina
CO River Rat
Also, it's tough to adjust the cable lengths to make sure the tongue doesn't hit the ol' pavement in case of a disconnect.
Steve
