'40 Bed Assembly Questions
Old Jan 31, 2009 | 07:04 PM
KGP50's Avatar
KGP50
Anyone able to help with this? New bed for my '40 project (MackProducts) ... no instructions, no old bed for reference. The picture shows the front bed panel with the 1/2" vertical lip shown in position on the outside of the bed side panel. My question is, on an original bed, does this lip fit on the inside surface of the bed side panel or the outside surface? Yes, I've spoken with a company rep. but let's just say the communication was a little less than 'clear.' My early '50 F1 isn't much help with this either ... it has an aftermarket bed too (Mar-K). If it fits inside, I'm off and runnin. If it's outside, I presume the lip also fits over the front stake pocket lip which would first be attached to the side panel. (?) I'd appreciate any advice available. (Thought I'd try this forum first .. will try the older trucks also).
Ken
Old Jan 31, 2009 | 07:17 PM
49willard's Avatar
49willard
Ken, On my original 49 bed (steel floor like a 40) the flange is on the inside of the bed. Incidentally, I replaced the steel floor as well as the wood under the steel floor. It is not a trivial task. I have 2 spot welders. I talked to Mack Hills himself before I attempted the floor.
Old Jan 31, 2009 | 09:34 PM
KGP50's Avatar
KGP50
Thanks Bill. That's what I was afraid of ... the panel just doesn't seem to fit best that way. But, I got the bed as part of a project the last owner needed to get out of. I think he may have pre fit things slightly wrong. Anyway, I sure appreciate you looking.
- Ken
Old Feb 1, 2009 | 10:59 AM
49willard's Avatar
49willard
Ken, Assuming that you are putting a new stock steel floor in your 40 bed, when you get to that point I can share with you my lessons learned on the installation.
Old Feb 1, 2009 | 11:39 AM
KGP50's Avatar
KGP50
Thanks Bill. I'm actually going to put an oak floor in it. But, I will be back with some questions about the sub rail and rear sill a bit later.
-Ken
Old Feb 1, 2009 | 01:49 PM
49willard's Avatar
49willard
Ken, Smart move going with the oak floor. I put the steel floor in but would recommend that others go the oak floor route. I did replace my original rear sill but have not done other bed work. I was fortunate, my bed was/is in great shape. I replaced the steel floor because it was so badly dented but not rusted. I can't totally blame po's since I used it as a work truck hauling engines, Jag IFS and other lumps of steel for a number of years before starting the current build.
Old Feb 1, 2009 | 05:31 PM
KGP50's Avatar
KGP50
Bill, I put oak in my F1, finished it natural with marine spar varnish, and it turned out great. Like you, I replaced my original F1 bed when I was doing that build because between the dents and rust out, it was just more than I was confident to tackle at that time. I remember though, that it was basically the same structure as the one I'm putting together for the '40. Different dimensions I think, but same parts. Wish I had it now for reference.
- Ken
oscajo
Mar 9, 2014 01:00 PM
BCHauler
Aug 20, 2011 12:50 AM
RANGER589
Paint & Bodywork
Jun 30, 2011 07:20 AM
barbsbuddy
Jan 8, 2006 08:58 PM
Torky2
1978 - 1996 Big Bronco
Dec 1, 2003 08:29 AM
