One last differential question
Old Jan 31, 2009 | 04:33 PM
desert sled's Avatar
desert sled
I am having a tough time getting the 75-140 synthetic gear oil, but there are plenty of 85-140 conventional oils available. Does it matter if I use a heavier wieght oil, I tow alot in the summer heat. Thanks in advance.
Old Jan 31, 2009 | 05:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That was funny.
Advance Auto has Mobil 75 -140 synthetic on the shelf here.
Autozone only has Mobil 75 - 90 synthetic on the website.
NAPA online is getting to be a mess finding anything.
Given the heat where you are located I don't think the heavier oil will be a problem.
Old Feb 1, 2009 | 05:10 PM
ford trans tech's Avatar
ford trans tech
you can use any conventional gear lube sae 90 sae 80w90 etc.
Old Feb 1, 2009 | 05:23 PM
flamebuster's Avatar
flamebuster
i prefer to use an example for emphasis on my point. The main gear box on our 4 row potato digger would get so hot the paint would literally burn with 90-140 conventional. After installing synthetic 90-120 it would still get quite warm but you could keep your hand on it. Now you can draw your own conclussions, hope this is helpful
