Dash removal
Old Jan 31, 2009 | 12:51 PM
Estam's Avatar
Estam
Dash removal
https://www.ford-trucks.com/forums/3...ml#post2721173
I perfectly good thread shows removal of the stereo but I am unable to see the pictures in post #8 - Any suggestions please...
Am trying to remove the stereo and dash pad.
Old Jan 31, 2009 | 04:45 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I tried 2 times and none of the pics will load sorry.
Old Jan 31, 2009 | 04:47 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
The user most likely moved or deleted the pictures from the source that it was uploaded to.
Old Feb 1, 2009 | 11:05 AM
clydesride's Avatar
clydesride
Did you get it out ok? I just did my new Alpine deck and had a little fun getting the old one out but as it said in the other instructions, just pry to the outside and shake it around a bit and it will release eventually. I am looking at my old one right now and the clips are about 1 1/4" in from the front of the deck. I used a few (4) mini screwdrivers and pried one side then held that side, inserted more drivers (the other 2) and pried the other side.
Got a cool mounting kit from the stereo shop with the harness... ever easy!!
The mount fit right in (I had the "deck mount" installed into the plastic mounting kit already) and snapped into place easier than I expected, then some quick wiring (I checked the wiring from the kit harness to the deck wiring and then did some measurements on the truck's harness) and good to go.
It may well have been easier than changing the dreaded left side headlight lamp! I had to remove the 6637 filter then the battery, battery box then change the lamp, put it all back together and pray when I tested it...lol
Hope you got into the dash ok.
Dave
Old Feb 1, 2009 | 12:11 PM
afreemanmd's Avatar
afreemanmd
I had to pull the dash to replace some of the bulbs that light up the instrument cluster. What you need to remove the radio is a set of DIN tools. They are really cheap <$10 bucks, and compared to trying to make them out of coat hanger, they are totally worth a few bucks
After that, drop the shifter in to '1' and tilt the steering wheel all the way down and kind of just pry it off.
Hope that helps!
Old Feb 1, 2009 | 02:11 PM
Estam's Avatar
Estam
Thanks guys, all done. Bought the DIN tools, missed the bit about having to pull them outwards to remove radio, finally figured it out. I also replace my dash lights while I was in there, 5 #194's and cleaned the lens. I made a couple of wooden tools out of 9 inch dowels, just filed ends down to a point, saves making marks on the dash while trying to persuade it. Later...
Old Feb 1, 2009 | 02:23 PM
afreemanmd's Avatar
afreemanmd
glad it worked out!
I took the whole dash apart to replace 1 darn light bulb. Now another one's going out. Next time, im going to led!
Old Feb 1, 2009 | 03:45 PM
weekendwarriorfsw32
Master of Strokes
Hope that helps!
Where did you buy your din tools?
Old Feb 1, 2009 | 03:50 PM
afreemanmd's Avatar
afreemanmd
I bought them a while ago, but if memory serves, I think it was at the local auto parts store. (I think it was autozone)
Hope that helps!
Old Feb 1, 2009 | 03:55 PM
weekendwarriorfsw32
Master of Strokes
Hope that helps!
Thanks dude!
Old Feb 1, 2009 | 04:24 PM
Big_John's Avatar
Big_John
I found the DIN tools at Wally World
Old Jan 17, 2010 | 08:47 PM
croozer's Avatar
croozer
my dash pad is peeling how hard is it to remove just the pad ?
Old Jan 17, 2010 | 11:13 PM
wallz's Avatar
wallz
The pad on top of the dash, under the windshield? If so, you don't want to go there and are better off repairing. A few weeks ago I ripped apart the dash on an f350 to find a lost necklace, dropped into 1 of the air vents. 7 hours, one windshield replacement later I was able to take apart, find and put things back together. The upper dash is one complete unit.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Jan 17, 2010 | 11:40 PM
croozer's Avatar
croozer
thanx for the info i was afraid of that
cheers
O SEA D
May 30, 2010 03:33 AM
captandy
Nov 19, 2009 06:34 PM
Pearlwhite94
2004 - 2008 F150
Apr 8, 2008 12:20 PM
pakrfan
Jan 13, 2005 08:14 AM
dtustin
2004 - 2008 F150
Aug 8, 2004 09:39 PM
