please help
Old Jan 31, 2009 | 07:13 AM
razzkazz's Avatar
razzkazz
Question please help
i have a 94 f150 whenever i start it the idle goes up and down and the voltage gauge does the same , sometime it evens out sometimes it quits, i have repleced the battery and altinator and it got worse...
Old Jan 31, 2009 | 07:18 AM
kcb37's Avatar
kcb37
Check to make sure the alt and battery connections are all clean and tight, to include grounds.
Old Jan 31, 2009 | 07:51 AM
Bob Gervais's Avatar
Bob Gervais
Does the idle ever smooth out? My 93 does the same thing sometimes, idle goes up and down, etc. If the idle goes low enough, the voltmeter dips down too.
I think your problem with voltage is more due to the idle issue than anything. I'm unsure what my problem is, I'm living with it until I get the time to check things out. I am leaning toward the IAC, and I also have an EGR code that may be causing a vacuum leak and messing up my idle.
Old Jan 31, 2009 | 08:06 AM
razzkazz's Avatar
razzkazz
the idle will even out after about 5 min of the up down crap thats if it dose not get too low and stall..i dont know but it has me crazy...
Old Jan 31, 2009 | 08:13 AM
Bob Gervais
Any codes from the computer? It may be worth checking the IAC (or IAB, this thing has been called a bunch of things over the years). Here is a link to fordfuelinjection.com that details IAC operation, testing, and cleaning: Ford Fuel Injection Idle Air Bypass (IAB)
There is a bunch of other really useful knowledge on there too, for troubleshooting and repair. It's an excellent site!
Old Jan 31, 2009 | 01:15 PM
razzkazz's Avatar
razzkazz
well took the iac off and cleaned it real good with carb cleaner and that took care of it...thanks...
Old Jan 31, 2009 | 07:45 PM
Bob Gervais
Glad it worked out, and was almost free. Hopefully mine turns out to be the same issue.
