89 Ford 4x4 150
Old Jan 31, 2009 | 09:04 AM
42model's Avatar
42model
89 Ford 4x4 150
Hi, just joined. Got an 89 Ford F150 that has a problem, will try to explain. It dies, but will restart in about 10-15 min. runs fine for about 30 min -+. with no problem. Then does the same thing over again, dies, then starts running fine, for a short time. Could this be a problem with the fuel pump? or something in the firing? Good old truck otherwise,Would appreciate any suggestions. Thanks
Old Jan 31, 2009 | 09:35 AM
shift1313's Avatar
shift1313
what motor is in it?
Next time it does pull one of the plug wires and check for spark. Maybe the ignition module is heating up and loosing contact. Could also be a fuel issue
Old Jan 31, 2009 | 09:36 AM
jemini's Avatar
jemini
Pull the codes to help identify what's up. Could be a few things.
Old Jan 31, 2009 | 07:55 PM
bbfmavrick's Avatar
bbfmavrick
Sounds like fuel filter or module
Old Jan 31, 2009 | 08:53 PM
woodsnake's Avatar
woodsnake
Sounds like a fuel pump too, mine did that....
