somewhat ot, but new software issues!
Old Jan 29, 2009 | 09:24 PM
MissIndependent's Avatar
MissIndependent
Thumbs down somewhat ot, but new software issues!
all right, theories as to why all the smilies and buttons (bold, underline, insert picture, link, etc) may have suddenly quit working for me?? problem started following new website software...i have not changed or added any security settings on my computer. if i click "preview post," the edit window adds all sorts of html-ish junk as well...
this is bugging the u-know-what outta me! it's really making it a pain to use the site, and i can't even insert a mad face!
Old Jan 29, 2009 | 10:13 PM
helifixer's Avatar
helifixer
I was just at the Chapter leader forum and a lot of people are having this problem. here is a post from glruf that might help. they are still working on fixing problems with the upgrade so hang in there.
Bart
Internet Explorer
To reload a page and bypass the cache:
either: Hold the Ctrl key, and press F5.
or: Hold the Ctrl key, and click the Refresh button on the Start bar.
To completely clear the cache (see note above):
Internet Explorer 7
Click “tools”, "Delete Browsing History", and then "delete all". Make sure to click on the checkbox also delete settings stored by add-ons. Then click OK.
Old versions
Click on 'Tools' and then 'Internet Options' and choose the 'General' tab. Then click on "Delete..." under "Browsing history". In the 'Temporary Internet files' section, click 'Delete Files...'. You will then get a dialogue box asking if you want to delete just the temporary files, or all offline content. Choose the latter and click 'OK'.
To change cache settings (only do this if you are reasonably confident of what you are doing):
Selecting 'Tools' → 'Internet Options' → 'Temporary Internet files' → 'Settings...' allows you to make advanced configuration changes to the cache.
There is an option labeled "Check for a new version of stored pages:" This does not bypass the cache, it merely determines how often the browser asks if there is a newer version available.
Mozilla family
This includes Firefox, Netscape Navigator (versions 6.x and 7.x) and SeaMonkey.
either: Press both Shift and Ctrl and then press R. (Alternatively, hold down the Ctrl key, and press F5.) On a Mac, use the Command key instead of Ctrl.
or: Hold down the Shift key, and click the Reload button on the navigation toolbar.
From the 'Edit' or 'Tools' menu, choose 'Preferences' or 'Options'. Expand the 'Advanced' options and choose 'Cache' or 'Privacy'. Click the button called 'Clear Cache'.
In newer versions of Mozilla Firefox, you can easily clear the cache, history and cookies: Hold down the Ctrl and Shift keys, and press Delete (or Del), then choose what you want to remove. Or from the 'Tools' menu, select 'Clear Private Data'.
For older versions of Mozilla Firefox, go to 'Tools' → 'Options' and click on 'Privacy' (picture of a key) in the sidebar of the window that pops up. Click the 'Clear' button that is next to the word 'Cache'.
To disable caching (only do this if you are reasonably confident in what you are doing):
For Firefox
Choose Tools | Options...
Choose Advanced at the top
Choose the Network tab
Change the cache size to 0 (zero).
For SeaMonkey
Choose Edit | Preferences...
Expand the Advanced item near the left bottom
Choose Cache item
Change the Size value to 0 (zero).
FireFox has memory caching, which might also need to be considered when troubleshooting cache-related issues.
In the address bar, enter 'about:config'
Filter the configurations options by entering 'cache' in the filter at the top
Change browser.cache.memory.enable to FALSE
Safari
for version 3 or newer:
either: Hold down the Command key, and press R.
or: Click the Reload toolbar button.
(In Safari 3, "regular" reloads will always bypass the cache. [1])
for version 2 or older:
either: Hold down the Command and Shift keys, and press R.
or: Hold down the Shift key and click the Reload toolbar button. (This may not work in all versions of Safari)
From the 'Safari' menu, choose 'Empty Cache...' or hold down the Option and Command keys and press E.
To disable the cache permanently (this method only works on old versions of Safari 2 on OS X 10.4 and previous versions, and is not recommended as it may potentially (although rarely) cause system instability):
Quit Safari by choosing 'Quit' from the 'Safari' menu, or by holding down the Command key and pressing Q.
Open a Terminal window by double-clicking 'Terminal' within the 'Utilities' folder, which is within the 'Applications' folder.
Type the following commands, which are case-sensitive, each followed by the Enter key:
rm -rf ~/Library/Caches/Safari
touch ~/Library/Caches/Safari
Quit Terminal by choosing 'Quit' from the 'Terminal' menu, or by holding down the Command key and pressing Q.
Relaunch Safari.
Google Chrome
To clear the cache:
Go to the Tools menu (the wrench on the upper right of the browser) and click on Clear browsing data...
Select the types of data you want to clear
On the Clear data from this period: drop-down list, select one of the following:
Everything to clear all the data you selected;
Last day to clear the data only from the last day;
Last week to clear the data only from the last week; or
Last 4 weeks to clear the data only from the last 4 weeks.
Opera
Reloading a page:
Press the F5 key to reload from the web (and bypass the cache)
Or hold down the Shift key, and click the Reload button on the navigation toolbar.
Or Empty the cache completely (see below).
Or Click edit this page, and save the page without making any modifications (this doesn't affect the page history).
To completely clear the cache :
From the 'Tools' menu, choose 'Preferences'. Expand the 'Advanced' options and choose 'History'. Click the button called 'Empty now'.
Alternatively, you can easily clear the cache, history and cookies: From the 'Tools' menu, choose 'Delete private data'. Click 'Details', make sure that 'Delete entire cache' is selected, and then choose any other data you want to remove.
To disable the cache permanently (only do this if you are reasonably confident of what you are doing):
From the 'Tools' menu, choose 'Preferences'. Expand the 'Advanced' options and choose 'History'. Click on the dropdown for 'Disk Cache' and select Off.
Konqueror
either: Press F5.
or: Click the Reload button on the toolbar.
(Unlike other browsers, Konqueror seems to bypass its cache whenever you reload a page.)
From the 'Settings' menu, select 'Configure Konqueror'. Scroll down to select the icon labeled 'Cache', and click the button labeled 'Clear Cache'.
Flock
Go to the Tools menu and click on Options
Go to Privacy and then, under Privacy, click on Cache
Click on Clear Cache Now
Flock v1.0.8 for Mac Instructions:
Go to the Flock menu and click on Preferences
Go to Privacy tab and then, under Private Data (bottom field), click on the Clear Now... button
Select the Cache checkbox (only, or in combination with other desired options)
Click the Clear Private Data Now button
Old Jan 29, 2009 | 10:26 PM
c00nhunterjoe's Avatar
c00nhunterjoe
wow, thats alot of reading.
Old Jan 30, 2009 | 06:10 AM
Neal 97 250's Avatar
Neal 97 250
helifixer, Good info. Reps sent
Old Jan 30, 2009 | 07:40 AM
helifixer's Avatar
helifixer
but you can just browse through it and only use the paragraph that is applicable to your browser.
Old Jan 30, 2009 | 09:46 PM
MissIndependent
does clearing the whole cache do more good than deleting cookies? tried that already and then had to log into every single saved site allll over again...ugh!
Old Feb 1, 2009 | 04:21 PM
DiamondK's Avatar
DiamondK
Mine works great
Old Feb 6, 2009 | 08:53 PM
MissIndependent
still no smilies or other posting buttons but plenty of html junk...also unable to figure out how to get sig picture to show again. it's driving me crazy, it's so difficult to use the site. are the bugs supposed to be worked out of this yet? my computer is old, but i didn't think it was THIS ancient!
Old Feb 7, 2009 | 07:55 AM
Cuda_jim's Avatar
Cuda_jim
Here's why your picture isn't working. It's posted at the top of the opening page of this forum titles "My signature isn't working - what is wrong?"
https://www.ford-trucks.com/forums/f...ncement98.html
Can't help you with the smileys but you can have this one
Old Feb 10, 2009 | 07:24 PM
MissIndependent
trial
still having issues, seems like re-loading with ctrl and f5 has helped the smilies and buttons...i have pictures again!
still no luck with getting the above (my sig picture) to show up again...i tried following the directions in the sticky note...nothing going
Old Feb 10, 2009 | 08:25 PM
helifixer's Avatar
helifixer
what browser are you using?
Old Feb 10, 2009 | 08:30 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Have you read this yet? https://www.ford-trucks.com/forums/f...ncement98.html
EDIT: never mind. Just noticed the sticky note comment.
Old Feb 10, 2009 | 08:49 PM
cookie88's Avatar
cookie88
FTE Emeritus
Ok....got a question. When you say "i tried following the directions in the sticky note", what did you mean?
Have you tried going to your User CP, then click on the "edit signature" tab, then scroll down to the editing section and try to upload it directly from your hard drive to your sig.
Old Feb 10, 2009 | 08:51 PM
JethroF250's Avatar
JethroF250
virus maybe? been lookin up dirty PSD vids have you? YOU BAD!!! lol
Old Feb 11, 2009 | 10:35 PM
MissIndependent
success! thanks i didn't think you could pictures that weren't properly uploaded to fte...and i have yet to figure out what the difference is between gallery and album
