door wiring
#46
I used the electric life looms too like Sam did on both my trucks, I'd say they are the best on the market because of the swivel that eliminates the binding and kinking the others include. How I did my install was by first locating the center of the hole on the door post and drilling a 1/8" hole, then closed the door and drilling through that hole into the door so your holes line up. Then used the step drill bit to bring it to the proper sized hole for mounting..
#47
Received 4,135 Likes
on
This is on my panel , I needed room for extra wires so have 2 looms on the left side and 1 on the right side
These are on a 56 but understand the slant cab doors are somewhat different around the hinges. On the 56 I also had to drill a hole through the pan that divides the inside of the door
#48
#49
on
#51
on
This is my pickup and you can see I used a smaller hole in the face of the door and I was still able to tighten thos set screws in that collar I mentioned. If drilled the correct size you could use a plug to cover that hole if you're not using interior door panels. Perhaps one of those electrical plugs that are used to fill in an unused hole in an electrical panel like this
Just a suggestion for thought, it could be painted to match your door
#52
#53
on
#54
you will want some blocker material in the kick panel so the bit doesn't grab your fuse panel wires...
always fun finding out later stuff you should have done sooner!...
#55
i think the step bit will also fit in one of the drill bit extensions (I had to buy one from Lowes for a different purpose), so you could drill from the door side... the pilot hole will help with alignment..
I was looking at how far my door opened and that i could never drill the door from the outside without the drill chuck screwing up all my paint but an extension like you mention might just work. Ill have to check it out.
#56
here is the one I bought (to drill a hole in my attic to run power to a wall mounted tv)
actually from home depot, not lowes
https://www.homedepot.com/p/BLU-MOL-...3406/205624234
benbuilder
13
05-03-2017 04:02 AM
meborder
07-03-2015 06:24 PM
