smoke on start up
Old Jan 29, 2009 | 12:35 PM
Red Cobra's Avatar
Red Cobra
smoke on start up
i smoke at start up it goes away after warming up but i can smoke out a parking lot haha is there anything i can do to fix this other than rebuilding the moter its pissing me off i am going through oil as well i know there is a small small leak but it looks like im burning a bunch off at start up also it seems like it has a bit of a miss at first and at times almost sounds like a nocking .... or am i due for a rebuild .... thanx.
Old Jan 29, 2009 | 01:21 PM
dyoung14's Avatar
dyoung14
it could be your valve guide seals, going out, im having simalar problems as you are, mine uses a quart of oil in 160-200 miles so im up the same boat you are
Old Jan 29, 2009 | 02:29 PM
Lazy K's Avatar
Lazy K
What color smoke is it? Could be a couple of bad glowplugs, or more likely, a bad injector.
Old Jan 29, 2009 | 03:20 PM
dyoung14's Avatar
dyoung14
well i was going to ask him the same thing but he has oil consumpsion, so my does about the ssame thing he says his does and all my glow plugs are brand new and injectors are in great shape so im sure mine is an oil problem
Old Jan 29, 2009 | 06:07 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How cold is it where you are at?
Lots of white smoke right after starting is normal with very low temps.
No spark to ignite the fuel, a cold engine does not burn the entire fuel charge in the cylinder.
So white fuel smelling smoke is the result.
Old Jan 30, 2009 | 12:05 AM
Red Cobra's Avatar
Red Cobra
about -10 at most and ya its not whight smoke its like a blue black and ya i do go through oil i have not kept track of how much as of yet but enough to keep an eye on it every week or 2 and how does a bad injector or bad glow plugs cause this?
Old Jan 30, 2009 | 12:44 AM
91f2504x4's Avatar
91f2504x4
A glow plug that is not working will cause that cylinder not to burn the fuel very well until it warms up to the temp of the other cylinders. If an injector has a bad spray pattern or is dribbling fuel out, this will lead to unburnt fuel as well and cause a lot of smoke. If an injector is leaking fuel it will cause a knocking due to the predetonation, this is exaggerated by the cold Advance, which would explain why you don't notice it as much once it warms up.
Old Jan 30, 2009 | 03:17 AM
1991F350's Avatar
1991F350
is it abnormal for a 7.3 to not smoke? my 91 F350 doesnt smoke at all when i start it, only time it smokes is when i hammer on the skinny pedal, and thats only a puff of black smoke and it dissipates. ive got all new plugs and injectors in it, and no oil gets burned. i remember my folks had a '95 PSD that smoked like a chimney when it would be started and when they were on the throttle.
Old Jan 30, 2009 | 03:50 AM
LCAM-01XA's Avatar
LCAM-01XA
the 7.3 shouldn't smoke an oil smoke, it has the "positive" style valve seals which let very little oil past them (valve guides absolutely hate this tho). As far as fuel smoke goes, it will only smoke as much as you want it - mine used to leave off occasional puffs of dark smoke when I'm accelerating at low rpms in OD, I've since turned the pump up a bit (less than 1 flat actually) and now under the same conditions it smokes more, but nothing like a hopped-up Cummins or DuraMax, and oddly enough it now getts better fuel economy, 18mpg freeway vs. 16 before. Strong startup puff and lots of low-rpm smoke is typical for the mechanically-injected turbocharged engines, they are designed to work with the turbo so until it spools up they're overfueling a bit, which is why you see the older 18-wheelers smoking for the first few seconds after every upshift. The PSD should not smoke like a chimney though, it has electronic injection which takes into account how much boost you have to determine how much fuel to dump, maybe someone has messed with it through a PCM chip or something?
Old Jan 30, 2009 | 12:11 PM
Red Cobra's Avatar
Red Cobra
its a blue black smoke for sure ! and well i dont plan on turning up the pump until i get my cross over pipe done its full of rust holes but i was just hoping that my truck is not going to leave me somewhere in between kelowna and dawson creek its like a 14 hour drive for me
Old Jan 30, 2009 | 03:25 PM
dyoung14's Avatar
dyoung14
get that cross over fixed that might help some of your smoke problems then check glow plugs then injectors then start thinkin of oil.
Old Jan 30, 2009 | 05:44 PM
Dave Sponaugle
Black smoke is to much fuel for the air.
Have you changed the air filter recently?
Old Jan 30, 2009 | 05:53 PM
rupejosh's Avatar
rupejosh
how about the cdr?
Old Jan 30, 2009 | 06:37 PM
joe f350's Avatar
joe f350
mine smokes alot did u turn up the ip
Old Jan 31, 2009 | 01:14 PM
Red Cobra's Avatar
Red Cobra
Cdr ? And no I have not touched the injection pump. And its more blue then black when it smokes I know the black is fuel and my filter is near new putting a cold air on it soon anyway but last night I have developed a rough idle shakes the truck this is after a 3 hour drive ...
