p0113 code
Old Jan 29, 2009 | 10:25 AM
PsD007.3's Avatar
PsD007.3
p0113 code
intake air temp high input isnt throwing a chech engine like but is popping up on my OBDII...i have an afe stage 2..just ignore it??
Old Jan 29, 2009 | 11:20 AM
F350-6's Avatar
F350-6
Not too big a deal, but it will disable the high idle on cold days. What did you do with that little gray sensor in the old factory air box when you put the AFE in? If you've got the sensor plugged into the side of the AFE box, unplug it, clean the connector and plug it back in to see if that fixes it.
Old Jan 29, 2009 | 11:29 AM
PsD007.3's Avatar
PsD007.3
ok cause it is plugged in now it might be dirty then, is that why my high idle when its cold is kind of iriatic (sp)...
Old Jan 29, 2009 | 11:33 AM
F350-6's Avatar
F350-6
Probably so. If you unplug it, the high idle should quite working.
Old Jan 29, 2009 | 11:52 AM
PsD007.3's Avatar
PsD007.3
ok i tried cleaning it with brake cleaner we'll see what happens i just also noticed p0603 code??
Old Jan 29, 2009 | 12:19 PM
F350-6's Avatar
F350-6
Try some electrical contact cleaner instead. Rubber parts and wires don't always react too kindly to brake cleaner. It comes in a spray can in the same area the parts stores have the brake and carb cleaner.
P0603 is a common code with a chip or tuner installed. Just ignore that one.
Old Jan 29, 2009 | 12:26 PM
PsD007.3's Avatar
PsD007.3
ok thanx man
Old Jan 29, 2009 | 12:42 PM
03_PSD's Avatar
03_PSD
I actually was getting the same code a few days ago and I now that it's cold I noticed my High Idle quit working. Purchased a new sensor for 12 bucks I think.
Old Jan 29, 2009 | 02:15 PM
PsD007.3's Avatar
PsD007.3
ok yea i'll have to see cause i dont think i ever did notice a high idle, now i did notice the ebpv closing but idk if i noticed the high idle, and thats not a dealer item right??? like i i can get it at napa, or advancded??
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
1978 - 1996 Big Bronco
May 25, 2002 03:08 PM
broom
Nov 24, 2001 12:46 PM
