Hard shifting 4R100
Old Jan 28, 2009 | 11:33 PM
'86_150's Avatar
'86_150
Hard shifting 4R100
Hi, i bought in a 2003 F250 with the 7.3 in august it has 150,000 miles and it shifts hard going from 3rd into OD it seems to have been slowly getting worse. also if i am on a hill and i put it in reverse to back up the hill my truck will roll forward sometimes. is that a TC problem? thanks for any ideas
Old Jan 29, 2009 | 10:35 AM
jk080's Avatar
jk080
Transmission Rebuilder
The rolling forward isn't a converter problem, check the fluid level. The harsh shift is a uncommon complaint, it might be possible that the converter clutch is engaged during the 2-3 and 3-4 shift, that can make things a little bumpy. It needs to be checked by someone that has a scanner and can watch the converter to be certain.
Old Jan 29, 2009 | 10:34 PM
'86_150's Avatar
'86_150
the fluid level is full, i flushed and replaced the filter and fluid about a month ago hoping it would help but it hasnt.
