1966 - 1977 Early Broncos
lockers ????
Old Jan 28, 2009 | 09:02 PM
76 crew's Avatar
76 crew
lockers ????
if i want to put lockers, say an aussie locker in the rear of my 72 sport, does that mean i automatically have to upgrade to 31 spline axles, i think i'm stock at 28 or 29 spline, right ???
i was thinking of going to 4.56 gears, anyway, but now wondering if i gotta spend more on axles too.
Old Jan 28, 2009 | 10:33 PM
RCrawler's Avatar
RCrawler
It looks like the only spline count they offer is 31 spline. I would recommend a good set of aftermarket alloys as a good upgrade if you are actually going to be wheeling your Bronco. Stock is 28 spline.
Jason
Old Jan 28, 2009 | 10:37 PM
76 crew's Avatar
76 crew
you would think for a lunchbox locker, it would be geared toward smaller tires, and stock axles.
i can see guys with detroits having to upgrade axles.
any suggestions on "good aftermarket alloys"
Old Jan 29, 2009 | 03:06 AM
RCrawler's Avatar
RCrawler
I've had Currie axles in mine going on 14 years. They've held up well for what I've done with it.
I hear good things about Moser and Dutchman.
Jason
Old Jan 29, 2009 | 04:58 AM
Sparky83's Avatar
Sparky83
what size rear end does the 72 have in it?
Old Jan 29, 2009 | 10:17 AM
RCrawler's Avatar
RCrawler
A 28 spline, 9"...
Jason
Old Jan 29, 2009 | 11:06 AM
Sparky83's Avatar
Sparky83
moser has a Detroit locker for the 9" thats 28 spline.. and theres the Detroit TrueTrac that also in a 28 spline for the 9"..
according to the description the truetrac operates more like a limited slip for better street performance but still functions like a locker...
both for the 9"
Detroit TrueTrac comes in 28 & 31 spline....
the Detroit Locker comes in 28, 31, 35 spline...
Old Jan 29, 2009 | 12:07 PM
'67Pony's Avatar
'67Pony
The Powertrax Lock-Right lunchbox locker is available in 28 or 31 spline for the 9".
Old Jan 29, 2009 | 12:11 PM
76 crew's Avatar
76 crew
i'm gonna start researching all these options you guys put up.
thanks.
Old Jan 29, 2009 | 12:13 PM
Sparky83's Avatar
Sparky83
np mate..just glad i could help for a change
Old Jan 29, 2009 | 02:10 PM
RCrawler's Avatar
RCrawler
I was only referring to the Aussie locker that you were originally inquired about. Of course there are other alternatives to replace them with if you want to keep the original axles.
If you are installing a locker though, it is a good idea to replace the original axles. And when you are changing the differential anyways, the upgrade to 31spline is a big strength improvement over the factory 28.
What size tires do you plan on running? What kind of four wheeling are you going to be doing? Does it have any type of limited slip now? If it does, the case won't accept a drop in locker. I don't like recommending them anyways because the factory cases are not very strong.
Jason
Old Jan 29, 2009 | 02:23 PM
Sparky83's Avatar
Sparky83
i agree.. if your going to do the locker id go ahead and upgrade...especially if its gonna be a track truck, huge power additions to the engine, or rock crawler..
i didnt know if he was just wanting it for an upgrade to use on the street or what... thats why i put the others out there since there wasnt any specifics on what he was planning to do with the truck...
Old Jan 29, 2009 | 06:45 PM
76 crew's Avatar
76 crew
i'm running 35's now with an nv3550, and its okay for the street, i only do some trail riding, and most of my off road is on the sand, so i need at least one of my axles locked, and going to 4.56 cause on the sand my 4 hi is too high, so i have to 4 lo it all the time.
Old Jan 29, 2009 | 09:40 PM
RCrawler's Avatar
RCrawler
Regular Detroit Locker and 31 spline axles, then. I don't even use 4wd most of the time in the sand with this setup. Only if I get myself stuck after being stopped or if I'm climbing a major dune.
Jason
Old Jan 30, 2009 | 02:25 AM
76 crew's Avatar
76 crew
regular detroit -
ok forgot to mention that i'm probably 70-80% street.
....been reading quite a few posts, and it's split 50-50 some saying detroit is not too street friendly.
...and some are saying if your only going to lock one, lock the front.
your opinion???
