Pyrometer/egt kit
Old Jan 28, 2009 | 05:38 PM
APOLLO TROY's Avatar
APOLLO TROY
Pyrometer/egt kit
Were is the best place to weld the fitting for the prob? I have the truck apart for head gaskets so getting at a part is no problem.
Thanks in advanced.
Old Jan 28, 2009 | 05:53 PM
liv's Avatar
liv
on the manifold right infront of the drivers side
Old Jan 28, 2009 | 08:15 PM
06silvercrew's Avatar
06silvercrew
No need to weld it, its tricky to weld mild steel to cast iron. Its thick enough just drill and tap it.
Old Jan 28, 2009 | 08:49 PM
liv's Avatar
liv
ew thanks didn't read the weld part. Definitely don't weld it
Old Jan 28, 2009 | 09:37 PM
APOLLO TROY
I was thinking the prob went on exhaust side of the turbo or down pipe. The prob does go on the manifold and it will get drilled and tapped.
Thanks again
