2008 Spark Plugs
Old Jan 28, 2009 | 05:18 PM
Catmonkey's Avatar
Catmonkey
2008 Spark Plugs
I knew the infamous blown plug issue has been out there and supposedly rectified, but it seems Ford has a new solution to the problem. In researching spark plugs for a planned supercharger install, I found it very difficult to find plugs for my 2008 5.4. Here's why, a totally new plug.
Note where the plug threads on these plugs. Will it be problematic? I guess we'll see.
Old Jan 28, 2009 | 05:43 PM
Ryan50hrl's Avatar
Ryan50hrl
Actually...I don't think those are the plugs for the 2008's...i believe those are the plugs only for the 2004-2007.5 year...late 07 got a new head design that used a more conventional plug
Old Jan 28, 2009 | 05:54 PM
Catmonkey's Avatar
Catmonkey
Yes, I suppose you're right. Perhaps they didn't change much at all, but they are different part numbers. I guess I have more research to do.
Old Jan 28, 2009 | 06:09 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
those autolights are the HT0 model catmonkey.
you and I need them because of the boost. the normal F-150 doesn't need them though.
Old Jan 28, 2009 | 08:07 PM
Catmonkey's Avatar
Catmonkey
Well, it seems Autolite's listing is wrong for the 2008. Here is a pic I found of the old and new plug next to one another. New plug is on top. Ryan was right. I still need to find a colder version of the new plug.
Old Jan 28, 2009 | 08:15 PM
Ryan50hrl's Avatar
Ryan50hrl
try brisk plugs...they make colder plugs for the 04-07's...
Old Jan 29, 2009 | 02:58 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
catmonkey, do you you have the new 5.4 heads or the old?
that picture up in post #1 is the HT0 plug, and so is the bottom plug in post #5
the Autolight HT0 is the correct plug for the 04-early 08 5.4 3v and 4.6 3v motor. They are 1 heat range colder than the OEM PZT1F plugs that are in the 06+ motors.
Pretty sure the Brisk plug is the same heat range as the HT0 plugs
Old Jan 29, 2009 | 05:44 AM
Catmonkey's Avatar
Catmonkey
My head has the new plug. At the present time, it looks like Motorcraft is the only source for the new plugs. Autolite shows a listing for 2008, but it's the same plug used in earlier 3v heads, so their application guide is wrong. I got a good education in plugs used by Ford in the modular motors doing this research. None seem to have been "better ideas". I'm sure the aftermarket will make a plug sooner or later. Doubtful before my install takes place. If anyone hears or knows different, please let me know.
Old Jan 29, 2009 | 01:27 PM
Catmonkey's Avatar
Catmonkey
I contacted Brisk today and they are making a plug for the new head in two heat ranges. They're sold out, but are getting more plugs in next week. It's just not on their application guide as yet.
Old Jan 29, 2009 | 01:37 PM
Ryan50hrl's Avatar
Ryan50hrl
Did you have something against the motorcraft ones in the other heat range....brisk plugs are only rated at 25,000 miles
Old Jan 29, 2009 | 01:48 PM
Catmonkey's Avatar
Catmonkey
If you've got a number for a colder heat range, I have no problem with Motorcraft. So far, I've only found the number for the stock plugs I already have. I was hoping to find one range colder. I haven't placed an order yet. I wanted to get more information on plug when I do get around to calling. So far my contacts with Brisk were by e-mail.
Old Jan 29, 2009 | 03:09 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
call/e-mail troyer. I'll bet you he can get a line on the colder range plugs
your doing tunes with him anyways right?
Old Jan 29, 2009 | 07:12 PM
Catmonkey's Avatar
Catmonkey
I'll be buying some parts from Troyer, but I'm going to work with VMP on the tune. Roush says to use the stock plug. I'll see if Justin has a recommendation.
Old Jan 29, 2009 | 07:35 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Troyer and FTE Ken both say to use the colder plugs
make sure to post up your dyno charts. I'd like to compare FTE Kens charts with Troyer tuning vs. the VMP tunes
Old Jan 29, 2009 | 08:24 PM
Catmonkey's Avatar
Catmonkey
Here's a link to a dyno chart on an F-150 with a Roush intercooled supercharger he tuned that is posted on his website.
Bryan's 06 F150 5.4L with Rouscharger - VMP Tuning Message Board
I don't know how compatable their respect mods are. I'm not looking for maximum horsepower, just a good, safe, streetable tune. I'll post my results but it's going to be later this summer. They're trying to put together a dyno tuning session in Houston, otherwise it's a long drive to Florida.
jas88
2004 - 2008 F150
Sep 4, 2014 05:59 PM
CollinsCD
Aug 8, 2014 01:00 PM
amstel78
Feb 27, 2014 04:46 PM
Robert Gift
Jan 17, 2014 05:52 AM
Dogmann
Modular V10 (6.8l)
Oct 20, 2013 12:20 PM
