Sponsored by: Real Truck
Hard starting with remote start
Old Jan 28, 2009 | 01:55 PM
Downriver Thunder's Avatar
Downriver Thunder
I already know I may have a fuel issue but I notice when it's below zero and hit my remote start it takes multiple tries to fire the truck up with the remote start. My old X never did it with it's V10 but this 5.4L is doing it. Any ideas or just the nature of the beast?
Old Jan 28, 2009 | 03:46 PM
350z's Avatar
350z
Smile
My 5.4l starts right away, your tach source may need to be changed,
some people use a coil, some use a injector, the coils seem to be a stronger source on the fords, some garages claim the coils as a source, can shorten their life , does yours have a hardwired tach source or a smart sense, tachless type? ,or the crank time may need to be extended ,as the fuel pump may not be getting fuel to the rail quick enough ,Craig.
Old Jan 28, 2009 | 06:16 PM
Beerstalker's Avatar
Beerstalker
I think you probably need to extend the crank time on your remote start unit. It should be in the instructions for your unit.
Old Jan 28, 2009 | 11:10 PM
ReAX's Avatar
ReAX
Check your voltage too. You can have a weak battery that just isn't enough to fire up the engine on remote, but will turn over with the key. For my battery the point seems to be around 11.8v.
Old Jan 29, 2009 | 07:22 AM
dredmond's Avatar
dredmond
There may also be a tach sensitivity setting/ switch that may help...Both my Directed Electronics units had them
Old Jan 29, 2009 | 07:46 AM
Downriver Thunder
I have to look and see what kind of remote start it is. I had it installed so I'm not sure. Thanks for the info.
Old Jan 29, 2009 | 06:35 PM
caprang's Avatar
caprang
Not sure on the 5.4 but I know some 6.0 diesels had this issue because there has to be oil pressure for the injectors to function. Oil is thicker in the cold weather and may take longer cranking time to reach the top of the motor. Im not contending that the 5.4 works the same way but it does sound like a similar issue. Im sure there is a safety mechanism built in to the truck if it doesnt sense oil pressure.
