high tranny temps
Old Jan 29, 2009 | 04:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Don't block the bypass. If there is a restriction and you don't have a bypass the rear of the trans won't get any lube and the trans will fail instead of run hot. It's more likely that you have a restriction in the cooler circuit than you have a failed bypass valve.
Old Jan 29, 2009 | 06:04 PM
05chop's Avatar
05chop
Who said anything about blocking the bypass?
Old Jan 29, 2009 | 07:24 PM
maevans's Avatar
maevans
Originally Posted by travis dasher
Thanks for the help Chop. I will go by NAPA today and get the parts. Would it be a good idea to get the aluminum spacers to put on the banjo bolts to block the holes, that way the fluid always goes into the cooler? Or just not worry about it. Thanks again.
I think Travis did.
Old Jan 29, 2009 | 08:34 PM
Mark Kovalsky
Yes, Travis did, and I was replying to him. Sorry that wasn't clear.
Old Jan 29, 2009 | 09:55 PM
05chop's Avatar
05chop
Travis was talking about the spacers in the lower right hand picture.Those who didn't want to braze up there own could buy spacers from john wood. Read the acticalFord Super Duty 4R100 Tranny Bypass Line Photo
Old Jan 29, 2009 | 10:37 PM
travis dasher's Avatar
travis dasher
Thanks for all the help. NAPA didnt have the part but I wasn't really expecting them to so I called the dealer and they will order it tomorrow and it should be here by Mon or Tues. More expensive than I expected, $74, Oh well price you gotta pay out here. Thanks again
Old Jan 29, 2009 | 10:40 PM
05chop's Avatar
05chop
Pm me need to know more about your avitar
Old Jan 30, 2009 | 08:03 AM
Mark Kovalsky
After you put it on you need to run a flow test on the coolers.
Warm the trans up first. That will take a minimum of 10 miles of city type driving.
Have two buckets under the truck. Disconnect the cooler line at the rear of the trans. Put the line in one of the buckets. Have someone start the engine, and as soon as the flow is steady put the line in the second bucket for exactly 15 seconds, then put the line back in the first bucket and shut the engine off.
If you have at least one quart in the second bucket the flow is fine. I suspect you'll have fluid spraying out of the open port on the trans where you disconnected the line, which means either the coolers or cooler lines are restricted, or the new bypass is also bad.
Old Jan 30, 2009 | 10:01 AM
travis dasher
Thanks for the flow test tips Mark. I will keep you guys posted. Hopefully the bypass fixes the problem.
Old Jan 30, 2009 | 10:56 PM
flyguy99pwrstrk's Avatar
flyguy99pwrstrk
Couldn't you just disconnect both of the cooler lines and blow the cooler out with the compressor?
Old Jan 31, 2009 | 01:35 AM
05chop's Avatar
05chop
I guess you could if you think compressed air will do the trick!!
Old Jan 31, 2009 | 09:18 AM
Mark Kovalsky
What would that accomplish?
Old Jan 31, 2009 | 09:24 AM
  #28
flyguy99pwrstrk
to make sure the cooler isn't plugged
Old Jan 31, 2009 | 11:19 AM
  #29
rmilchman's Avatar
rmilchman
I bought one this summer from a local Ford dealer. I think it was about $55, took me 30 minutes to install / cleanup and only lost a few drops of fluid.
