Vibration Only on Take Off
Old Jan 29, 2009 | 12:42 PM
brian42's Avatar
brian42
Veteran: Navy
Originally Posted by BeBo03
I changed the rear dif. oil 6 months ago with Mobile 1 syn. However the problem was there before this and the syn oil did not fix the problem. The motor runs great so I'm sure it has to be coming from the drive shaft/or u-joints. Thanks for the input I'm going to do a re-grease on the drive shaft. It just amazing how little things like air pressure and grease can do wonders on how your truck drives.
I agree. I swapped to Mobil 1 Syn and have not had any problems and I haven't added any additional friction modifier.
Old Feb 2, 2009 | 10:20 AM
afonda's Avatar
afonda
Ok... I went to grease the slipyolk and there was no zerk. In fact there are no zerks at all anywhere on my driveshaft. There is a rubber collar by the carrier bearing but no way to grease it.
What up w/that???
Old Feb 2, 2009 | 10:43 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Yep, you got it! I guess it'a an attempt to make the driveline maintenance free.
To grease the slip yolk you need to drop the driveshaft. Step #1, MAKE SURE THE WHEELS ARE CHALKED! Don't want to see anybody get run over!
Remove the straps that hold the rubber boot in place on the driveshaft. Mark the slip yolk and the driveshaft. They need to go back together the same way they came apart. You can't be off one spline or it could mess up the balance of the driveline. Drop the driveshaft by removing the straps on the u-joint at the rear axle. Clean the old grease off and put some new grease back on the splines. You will want to put some grease on both the splines and the slip yolk. Re-install the driveshaft. You can use some tie-straps to hold the rubber boot in place. This is important to keep contaminants from getting in there.
Old Feb 3, 2009 | 07:41 AM
afonda's Avatar
afonda
Since I need to replace the carrier bearing anyway... I will just wait and do this all at the same time.
Thanks for the slip yolk greasing instructions.
websurfer
19
Feb 21, 2024 06:19 PM
clarkbre
Apr 28, 2014 10:40 PM
jetact
Sep 14, 2010 09:30 PM
