Help
Old Jan 28, 2009 | 05:12 AM
7camaro3's Avatar
7camaro3
Help
I was plowing this morning my 1999 7.3 shut off tryed to restart nothing I noticed there is no glow plug timer comming on on the dash display
Old Jan 28, 2009 | 06:06 AM
swaybar's Avatar
swaybar
check your fuses under the dash
Old Jan 28, 2009 | 06:36 AM
F350-6's Avatar
F350-6
Fuel bowl heater has shorted out. Unplug it (on the bak of the fuel bowl) then replace fuse #30 in your truck. Should start back up. You can run the truck with the heater unplugged.
Welcome to FTE.
Old Jan 28, 2009 | 03:24 PM
7camaro3's Avatar
7camaro3
Thanks , The fuel bowl heater did short out . I unpluged the heater ,replaced the fuse and it starts and runs . Thanks again
