Parts duplicator
Old Jan 27, 2009 | 05:52 PM
bobj49f2's Avatar
bobj49f2
Parts duplicator
Someone posted this on the HAMB, you've to check it out:
Jay Leno's Garage
Old Jan 27, 2009 | 06:21 PM
Julies Cool F1's Avatar
Julies Cool F1
Wow BOB!
That's incredible! It's almost like a Star Trek thing! The food replicator!
J!
Old Jan 27, 2009 | 06:40 PM
abe's Avatar
abe
Did you check out the video of the 789 Corette? Wow! The guy that does it said there are only 2 limitations: your imagination and your pocketbook! Leno asked him what this will cost you. The guy said only your new corvette and 75 thousand bucks!
Old Jan 27, 2009 | 06:55 PM
56panelford's Avatar
56panelford
Originally Posted by Julies Cool F1
Wow BOB!
J!
Couldn't have said it better Julie, truely incredible, now if they made one of those big enough we'd be able to park one of the best in it and start producing full scale models of our trucks.
Old Jan 27, 2009 | 08:18 PM
bobj49f2's Avatar
bobj49f2
Yeah, if they could make the "Printer" about twenty times larger and replace the plastic string with MIG welding wire just think!
Old Jan 27, 2009 | 09:00 PM
4tl8ford's Avatar
4tl8ford
I want one
I could scan my wife - and print her up
no talking
no spending
wow
Old Jan 27, 2009 | 09:36 PM
CharlieLed's Avatar
CharlieLed
That is amazing. I had the opportunity to tour the Ford Research Facility near Dearborn in 2000 and they demo'd a 3D plasma spray tool that took a 3D image and built a metal 3D part from it. 7 seperate nozzles spraying molten metal onto a rotating turntable, building a 3D part from the bottom up...pretty cool stuff. They showed how this machine built a spindle for a front suspension...the part was strong enough to use on a car but cost prohibited it from use in production. Great way to test a design before going into production though. I would like to see that plasma unit connected up to this 3D scanner...good to see American ingenuity at work!
Old Jan 27, 2009 | 10:39 PM
OldgreenF1's Avatar
OldgreenF1
That is beyond amazing!
Old Jan 28, 2009 | 09:25 AM
49willard's Avatar
49willard
Truly a neat machine. Those of you who haven't explored Jay Leno Garage website should do so. My son got me hooked on it several years ago.
I am with Bob on this one though, the duplicator needs to work in metal rather than plastic. I do play around with the early cars some and find myself needing to make parts. I work some with a foundary that pours bronzes and aluminum and have duplicated a number of parts. What we typically do is build up the broken part slightly with bondo to accomodate for shrinkage due to cooling (I seem to remember that bronze is 1/8 shrinkage per foot), sand cast off the built up original and then final machine it.
Old Jan 28, 2009 | 11:58 AM
bobj49f2's Avatar
bobj49f2
Bill, the great thing about the knew technologies that keep evolving is you can tweak it to consider the many variations.
First, I think a printer could be made to work with metal and produce actual usable metal parts.
Second, the technique you mentioned about having to increase the size of the part to allow for shrinkage would be eliminated by inputting the material that is going to be used and automatically increase the size of the model.
I don't have any idea how this all works but I am always amazed at the fast pace technology operates at to meet our needs. I just wonder when this will all come about and it becomes cost effective for the average old vehicle owner to go down to the local parts fabricator have have a part scanned and fabricated while you wait, something like a Kinkos. Think of all of the stuff that we have today that we either didn't have or we couldn't afford when were were kids. I could list at least a dozen things the were considered way too expensive 10-20 years ago that we take as granted now, cell phones being one.
Old Jan 28, 2009 | 02:51 PM
49willard's Avatar
49willard
Bob,
In conversation with a friend that works with early cars and does some significant machining, he indicated that a mutual friend/old car buddy worked on the programming for one of these duplicators. I agree with you on technology advances over the years. A number of years back reading the book on Truman by McCollough It really hit me thinking about his life growing up in St Louis when it was really the frontier with horses and wagons and then dropping the Atomic bomb when he was president.
Old Jan 28, 2009 | 05:03 PM
thendrix's Avatar
thendrix
That has come a long way since the days of old. Years ago people would use what is called a panagraph or a "copy mill". It is basicaly two milling machine heads that are side by side. One has a probe in its spindle and the part to be copied on a table. The other has a cutting tool (end mill) and the material that the part will be made from.
The machine with the part and the stilus controls the machine that is doing the cutting by running backward and forward across the part and moving the cutting head across and up and down as needed.
There are also digitizers that can be run in CNC machines that do basically th esame thing. They take thousands of points from a part and store them in a memory file. The points can then be downloaded to a computer and plotted in a CAD or CAM system.
Old Jan 28, 2009 | 05:55 PM
4tl8ford's Avatar
4tl8ford
When I was in the Air Force we were upgrading the human body dimension sets used to make uniforms oxygen masks, chemical protective gear etc.
There were several colledges in the area that we used the students from and laser scanned them as that machine at Lenos did - this was in the mid 80's and the machine turntable etc were the size of a small house.
After scanning we would use a state of the art duplicator - it was a large vat of liquid polimers that another type of laser would travel over following the scan data points while firing at the polimer.
This would harden the liquid and on the next pass the polimer would rise an n'th of an inch and build another layer.
We would end up with a set of head forms to use for the masks.
It didn't allow for the internal moving items as this new one.
And I still want to duplicate my OldLady.
Old Jan 28, 2009 | 06:53 PM
LEckart's Avatar
LEckart
Isn't technology great! I'm in awe of machines like this one. And the great thing as pointed out by Leno: all American technology.
Old Jan 28, 2009 | 07:37 PM
havi's Avatar
havi
I'll have the Roast Duck
I watched the video when it was posted on the hamb, then I forwarded the link to a coworker. He comes up to me today with several hand-held sized shears that we make, saying our R&D engineer already had it done. I was impressed!
