BIG Thanks to DP Tuner, John Wood, Robin, Cris & Lisa!
Just wanted to publicly thank Jody & Diane, John Wood, Robin (PaysonPSD), Cris (Liftedgrocerygetter), and Lisa (Smokin) for the help this morning.
I was on my way to work on the freeway, just cruising along in overdrive in 80E on DP running 75mph, and I start to reallllly lose power. It's about 10* outside so I am immediately think my fuel is gelling up. I limp my truck on the freeway running 30mph! Get to work, and idle into the parking lot. Work was quick today, just 2 hrs, so I come back to the truck, and pull codes. I get the usual ICP, AIH stuff that I always do, and I also get a P 0732. Not good! That code is Gear two ratio error. UT OHHH. Tranny!
I first called Lisa, because I knew about her recent fuel problems, voicemail. Then I call Cris and she gets me the number for DP Tuner, thanks! Then I call DP.....voicemail. Then I call Robin, and with both of us talking thru the problem, I decide since I'm not getting the codes now, and it will run okay in stock mode, I takeoff driving home, 45 minute drive all freeway, no problems. I get ahold of Diane & Jody at DP just before I am home, and talk thru it with Jody....and he thinks because of the code I got it's a tranny problem, but suggests I call John Wood.
Not sure if you guys have ever talked with John Wood before, but he is INCREDIBLE. He knows these 4R100 transmissions inside & out like nobodys business! He tells me the code I got is probably from lack of fuel.....I am stumped. But he explains that when I started to lose power on the freeway.....by me totally romping on the throttle, and the fact that my fuel was either bad, or gelling...it threw that code. I was asking the tranny to do something outta the ordinary, but it is still fine! THANK GOD! I was already scared of the $5000 bill that I thought was coming lol.
So then Lisa calls back, and we talk and realize that our symptoms were pretty much exactly alike with fueling issues. I had already dumped a white DK bottle in the tank before leaving work, but she suggested I also get DK's Diesel 911 and use it. I changed out the fuel filter, added the 911 to the tank, and 50/50 in the fuel bowl and I am back in business! Big thanks to everyone....you all played a part in helping me and I really realllly apreciate it! Reps on the way when I can get you all!
The ULSD is getting everyone this year.
BTW - The white DK says right on it that it has NO ANTIGELLING PROPERTIES. Or something close to that. It's to be used with the summer blend diesel. The best DK to use for antigelling is the grey bottle. This is what I run from fall to spring. The 911 is used for already gelled tanks/lines and works great for un-gelling a system.
Glad you're back in business!
Yep.
White bottle:
http://www.powerservice.com/dfs/
Grey bottle:
http://www.powerservice.com/dk/
Anti-gel is in the white bottle...
About a month ago, I had to put me name on a waiting lists to reserve two bottles of 911 at Tractor Supply.
This year it's hard to find in the store's around here.
