Replacement Fuse Panel?
Old Jan 27, 2009 | 10:38 AM
1980FORD's Avatar
1980FORD
Is there anywhere besides maybe Ford dealer or a junkyard to get a replacement fuse panel for a 1980 F150? The problem I am having is the tab that holds the wire from the fuse box to the blower motor in my truck is broken and the wire is falling out. I have no heater and in PA that is a big problem! I turned the fuse panel around and there is no where to re locate the circuit on it so I either have to wire it in a different way ( I really don't want to do this) or find another fuse panel. Painless has a nice one but its $130 and I could not find one on LMC or Broncograveyard. Any suggestions on the panel or wiring problem would be greatly appreciated.
Old Jan 27, 2009 | 10:57 AM
JD IN NJ's Avatar
JD IN NJ
Parts stores sell in line fuses with wire ends.Its simple to install that .
Old Jan 27, 2009 | 11:06 AM
1980FORD's Avatar
1980FORD
I was planning on doing that possibly as a short term solution. I would also like to have it wired in correctly at some point. I was thinking about using a 30amp fuse. Do you think that is too much? Thanks for the reply.
Old Jan 27, 2009 | 11:22 AM
JD IN NJ's Avatar
JD IN NJ
Use the same size as fuse panel had for blower.
Old Jan 27, 2009 | 12:15 PM
Franklin2's Avatar
Franklin2
Your problem is not a common one, so you should be able to find a good one at the junkyard.
Old Jan 27, 2009 | 12:36 PM
1980FORD's Avatar
1980FORD
I wish that were true. Around here they have crushed and disposed of all cars and trucks more then 15 years old. The closest thing I would be able to come up with would be from a mid to late 90's truck and I don't think they are the same. Plus most junk yards around here would not sell only the box. They would insist on me buying the whole harness. I will look into it though. Thanks again.
Old Jan 27, 2009 | 06:21 PM
Franklin2's Avatar
Franklin2
Are these guys near you? They have cabs for sale, maybe they have some fuse boxes too.
1981
Cab
Ford Truck F150 NICE XLT 028288010 $295 ARichner Auto Parts USA-PA(Milesburg) Request_Quote 1-888-572-3428 Request_Insurance_Quote
1980
Cab
Ford Truck F100 000 A
0 F10024 $Call New Castle Auto Wrecking, Inc. USA-PA(New-Castle) Request_Quote 1-800-245-2226 Request_Insurance_Quote
Old Jan 27, 2009 | 07:25 PM
1980FORD's Avatar
1980FORD
Not real close. Probably about an hour to an hour and a half drive from here but worth a shot to give them a shout. Thanks for the info.
MontanaEE
Electrical Systems/Wiring
Aug 7, 2012 11:38 AM
1978-BBB
Oct 30, 2011 05:34 PM
mlevario99
Sep 1, 2008 01:06 PM
Billy4416
Oct 5, 2004 06:29 PM
mvtofino
May 23, 2004 11:37 AM
