Spindle tap needed
Old Jan 26, 2009 | 03:27 PM
drof46's Avatar
drof46
Spindle tap needed
I'm getting my king pins installed. I need the thread size to buy a tap and chase the threads on the top and bottom of the spindle. This is for the nut that has the grease zerk in the center. Anyone know the exact size of these threads. The powder coaters got a little carried away and covered up more than they should have. This is a 79 spindle if that matters.
Thanks
drof46's Avatar
drof46
Not to be confused with spinal tap, lol.
Old Jan 26, 2009 | 03:54 PM
Blackwaterforge's Avatar
Blackwaterforge
Could you use a thread chaser? Much cheaper and can be used on eight thread counts of any size.
You can also wrap threads with mechanical weld tape and it will endure the heat of powder coating and is easily cut off afterwards.
Old Jan 26, 2009 | 04:01 PM
Blackwaterforge
Dissregaurd my last post. I thought you were talking about the threads on the end of the spindle.
Old Jan 26, 2009 | 04:38 PM
camperspecial65's Avatar
camperspecial65
all you need to do, if possible, is take the cap that screws onto the spindle and figure out the die size...then get the tap size and clean out the threads...go slow...I have a friend who got some GM F body hood hinges done...with hood on...wouldnt budge...had to twist the hinge enough to break the coating...its super tough stuff...
- cs65
Old Jan 26, 2009 | 09:02 PM
drof46's Avatar
drof46
I was talking about the threads at the end of the spindle. The powder coating/damage is already done.
Thanks for the info on the thread chaser. I will have to look into one.
Old Jan 26, 2009 | 10:44 PM
Redmanbob's Avatar
Redmanbob
Take the Nut to Harbor Freight and size up a Tap to it. Pretty sure the large gauge kit has one that fits. I got a tap for the intakes water pipe and that was one of the smaller ones in the kit.
smithwoods
Feb 18, 2020 07:44 PM
1970f100guy
Apr 25, 2014 07:20 PM
CraigOutdoors
Mar 28, 2010 09:28 PM
jefxxo
Mar 15, 2009 08:05 PM
