which way do i turn?
Old Jan 26, 2009 | 10:39 AM
kupiec20's Avatar
kupiec20
the nut on the oil pan clock or counter? i know stupid question the nut was not moving either way and the other question is can i force it or will it crack the pan
Old Jan 26, 2009 | 11:17 AM
FARM69's Avatar
FARM69
I believe its your standard thread.
Action4478's Avatar
Action4478
Right to tighten,Clockwise, left to loosen ...counter clockwise
Old Jan 26, 2009 | 11:32 AM
Cuda_jim's Avatar
Cuda_jim
Ditto...Standard thread.....righty-tighty, lefty-loosey.
Old Jan 26, 2009 | 11:35 AM
kupiec20's Avatar
kupiec20
its like 10* out and it does not want to move will i cause the pan to break because of the cold?
Old Jan 26, 2009 | 11:47 AM
Cuda_jim's Avatar
Cuda_jim
I doubt you'll damage it but... anything can happen.
I would wait until it gets into a warm shop in case you need to repair something.
Old Jan 26, 2009 | 11:50 AM
CampSpringsJohn's Avatar
CampSpringsJohn
You and I may be brittle at 10 degrees, but not the metal. It would have to get a little colder for that. Just get a good socket and ratchet and go for it. If the filter is still on it, start it up and warm it up. It will let the oil run out faster, and help keep you a little warm while working on it.
Old Jan 26, 2009 | 09:20 PM
kupiec20's Avatar
kupiec20
still cant loosen the nut
Old Jan 26, 2009 | 10:08 PM
CampSpringsJohn
Well, it does come off. Turn it counter clockwise. Perhaps an impact wrench if you have one. Just make sure it's in the right gear. Do not use one to re-install it though.
