Sponsored by: Real Truck
bat die over night
Old Jan 26, 2009 | 10:19 AM
jemrecovery's Avatar
jemrecovery
bat die over night
i have a 1999 f550 the battiers keep die over night i check for a drain found one took off the fuse but bat keeps die when i check for ground on the frame or the motor these is none.... does anybody have the wiring to show the grounds?
Old Jan 26, 2009 | 10:22 AM
TexasRebel's Avatar
TexasRebel
same battery?
have it checked, it might not be able to hold a charge that long.
Old Jan 26, 2009 | 10:24 AM
jemrecovery
no not them same one put 2 new ones in it . should i have ground with out the bat hook up?
Old Jan 26, 2009 | 10:39 AM
99f350sd's Avatar
99f350sd
You have something staying on. Check glove box light or something like that. Hood light?
You don't have a ground issue! You have something staying on. If may not be easy to find. Alternators do this at times. Have it checked by an expert..if you can't find anything. Disconnect battery at night so you won't kill it. Every time you kill it 20% of the battery life is lost..
Dick
Old Jan 26, 2009 | 01:26 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
I think he's saying he disconnected battery and it goes dead. I'd take the truck in to where he bought the battery and have THEM check it. May be a bad alternator. A bad battery will kill an alternator..... 99f, does it stay running if you remove the ground cable from battery while it is running?
Old Jan 26, 2009 | 01:57 PM
ReAX's Avatar
ReAX
I know that's the common test, but disconnecting the battery while the engine is running can cause a substantial voltage spike. Which isn't good for the electronics.
I would start by charging the battery alone (disconnected from the truck). Then let it stabilize for a few hours (or overnight) then check it's voltage. A battery should hold 12.66v minimum, as there are 6 cells at 2.11v each. If the battery can't hold 12.6v then it needs to be replaced as it's internally discharging.
Old Jan 26, 2009 | 02:32 PM
skip mitchell's Avatar
skip mitchell
Another possibility is if the battery is hooked up,a diode made be bad in the alternator causing draw when shut off,the diode being a one way electrical check valve in the alternator.
Old Jan 26, 2009 | 02:39 PM
ReAX's Avatar
ReAX
That can be checked by DMM or test light. Disconnect the ground and put the test light or DMM in line between the ground terminal and the battery ground post. You should see about 20mA draw (normal) or more, then disconnect the charge wire from the alternator. If the light goes out or the draw drops off when you disconnect the charge wire, then the alt has a bad diode.
