Sponsored by: Real Truck
no 4x4
Old Jan 28, 2009 | 05:36 AM
50jd60's Avatar
50jd60
Just had mine fixed, was the vac. solenoid behind the battery on passenger side, they checked it and the ohms reading were bad, new switch and all is fine.
Old Jan 30, 2009 | 05:30 PM
jesse03ford's Avatar
jesse03ford
i talked to a dealer today they said it sounds like the 4x4 shift control module i checked the switch the indicator light works but the switch acts like it is not getting power i checked all the fuses in the cab again and they are fine the control module is 230 dealer only they said i was hoping for a cheaper fix it makes sense though when you turn the switch nothing happens it does not light up on dash or anything buy the light n the dash does work i checked it like you said where should i start with the module or ?????
Old Jan 30, 2009 | 05:40 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Without going through David's checklist, you're throwing money at it.
It could be the motor, fuses, relays, even just a bad connection.
Old Jan 31, 2009 | 05:18 PM
jasper007's Avatar
jasper007
F-250 (03) 4x4 not engaging
It finally seems to work IF the vehicle is warmed up for 15 or 20 minutes . But when its cold it wont work ????
ds4101
Apr 2, 2023 02:34 PM
skyoung
Oct 5, 2011 10:33 AM
goodtobeeme
1997 - 2003 F150
Dec 28, 2010 05:44 PM
frafer1
Jan 14, 2009 11:13 AM
jmwhelchel
Dec 13, 2004 02:37 PM
