Sponsored by: Real Truck
2" lift idea
Old Jan 25, 2009 | 10:56 PM
adgunn's Avatar
adgunn
2" lift idea
Hello all!!more questions...I'm looking for a small lift kit for my truck...found a decent looking 2" add-a-leaf kit from topguncustomz. its a front and rear kit, would i need to get track bar relocation kit?? i dont want much lift, just enough to perk it up...
Old Jan 26, 2009 | 06:12 PM
mwsF250's Avatar
mwsF250
2" lift? Should not need to relocate the track bar.
Do keep in mind that the add-a-leaf will make the truck ride harsher. Add-a-leafs work by preventing the leaf spring from flexing.
Old Jan 26, 2009 | 06:22 PM
ruschejj's Avatar
ruschejj
It's not cheaper, but, you can get the Fireston Ride-Rite air bags w/onboard compressor. Blow them up to about 50, maybe 70 psi and you'll get your 2" and you'll add capability as well. You can put a ton of material in your bed, level out the truck, drive normally.
The bags are really cool. You can also get a 2gal. reservoir tank and have onboard air for whatever you might want.
