Sponsored by: Real Truck
04 temp gage
Old Jan 25, 2009 | 08:59 PM
bayromer's Avatar
bayromer
04 temp gage
Just finished putting a 2004, 6.0 EGR delete in , a lot of work hope it sovles the loss of collant , but now I dont have engine temp and the CHECK GAGE light is on where is th collant sending unit located so I dont waste a lot of time looking for the unobvious. Thanks Frustrated in VA
Old Jan 25, 2009 | 11:47 PM
ReAX's Avatar
ReAX
Since you worked on it, try going over the area where you worked. I am not familiar with the EGR delete, but if you removed the ECT sender and reinstalled it with a thread sealer, check your thread sealer. It's possible the sender needs an engine ground and your seal is non-conducting. Or while you were working, you disconnected the sender harness. It's also possible that a wire got pinched or broke during the install.
Just some ideas to get your diagnostics started.
oldfordsrule
Oct 7, 2014 08:00 AM
ffengine51
Sep 22, 2011 09:48 PM
94 smokin stroker
Jun 17, 2010 04:17 PM
unluckylow
49
Dec 19, 2004 12:48 AM
rg0327
1983 - 2012 Ranger & B-Series
Aug 1, 2003 06:47 AM
