Fuel gauge issues
Old Jan 25, 2009 | 08:47 PM
70mazie's Avatar
70mazie
Fuel gauge issues
I have been having problems with my fuel gauge. Most of the times it appears to be dead. However, in a blue moon, I get a reading that appears accurate.
(1) Do you think the float is getting stuck?
(2) Is it best to change out the sending unit?
(3) Other things that I should check first?
Thanks in advance.
Old Jan 25, 2009 | 09:39 PM
Redcat Diesel's Avatar
Redcat Diesel
You might want to check the wire connections at the sender first. After that I would disconnect the sender feed wire and hook it to a good ground. Next turn the key on. The gauge should peg on full. If it does your problem is most likely the sender. If it doesn't the problem is in the gauge or wiring.
Old Jan 26, 2009 | 04:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F100/350 ~ 1961/77 Fuel Tank Sending Units & Float
The float is made of two pieces of copper soldered together, solder breaks down, fuel seeps in, float slowly settles towards the bottom of the tank.
The float is still available from Ford.
COAZ9202B .. Float
Fits all: 1957/79 cars & trucks.
MSRP: $7.41 // FTEpartsguy.com price: $5.34.
The in-cab fuel sender is now obsolete, a few dealers and obsolete parts vendors still have some.
D7TZ9275G .. In-Cab Fuel Sender / Obsolete / Fits: 1961/77 F100/350.
COTTAM-WALKER FORD in Taos NM has one.
STAR FORD L/M in Streator IL has one.
HARR MOTOR COMPANY in Worcester MA has one = 508-852-5111
MILLER OBSOLETE PARTS in Binghamton NY has one = 800-546-7278
GREEN SALES COMPANY in Cincinnati OH has two = 800-543-4959
AAA OBSOLETE PARTS in Howe TX has two = 903-546-0024
COLLECTORS AUTO SUPPLY in Oroville WA has ten = 800-414-4462
The under-bed auxillary tank that was optional on 1967/72 F100/350 Stylesides uses the same float as the in-cab tank.
DOTZ9275D .. Auxillary Tank Fuel Sender / Obsolete
PERRY PITRE FORD in Eunice LA has one.
GREEN SALES has three = 800-543-4959
That's it! No one else has any.
Old Jan 26, 2009 | 12:17 PM
70mazie's Avatar
70mazie
Thanks for the parts #S
NumbersGuru --- thanks for the parts #s and contact info
Old Jan 20, 2011 | 06:57 PM
svemike's Avatar
svemike
Smile fuel guage
I had the same problem. Other guages did the same thing, however. A radio noise suppressor choke is wired inline between power and the instrument voltage regulator. only 2 volts leaving volt reg.. removed choke and problem fixed. (and no radio noise)
Old Jan 20, 2011 | 10:43 PM
lucky_strike's Avatar
lucky_strike
COAZ9202B .. Float
i thought lmc or npd would have them too?
Old Jan 21, 2011 | 04:18 AM
NumberDummy
The sources I posted have original Gen-U-ine Ford parts.
Where do the parts come from that NPD or LMC supposedly have?
The float, prolly from FoMoCo as it's still available. The senders, if they have any, are prolly repopped...in China.
afonda
Feb 16, 2014 10:12 PM
valpro99
Jun 7, 2013 11:52 PM
smoky_diesel
Sep 4, 2009 10:06 AM
2K3 Mach
1983 - 2012 Ranger & B-Series
Oct 26, 2003 03:49 PM
