1990 f150/il
Old Jan 25, 2009 | 06:40 PM
Ohnjay's Avatar
Ohnjay
1990 f150/il
I have a 1990 F150 with a 300 cid 6 cylinder & 5-speed manaul transmission. My problem is that when I leave home and after 2-5 miles it will die and not restart. It cranks good but there is no spark to the spark plugs nor does the electric fuel pump kick on momentarily when the key is first turned on. Once is sits for 5 -20 minutes it will restart and run fine. It seems to be doing this more frequently. It runs fine while it's warming up on cold mornings.I've replaced the;fuel pumpfuel pump relayelectric ign switch on steering column.Do any of you know or have exerienced what would cause this?Thank you,John
Old Jan 25, 2009 | 06:48 PM
Fomoko1's Avatar
Fomoko1
Hey John, welcome aboard!
For help on your 1990 F150 problem re post in the 1987 - 1996 F150 And Larger F-Series Trucks forum: https://www.ford-trucks.com/forums/forum28/
Also visit your local IL chapter, meet the fine folks there too: https://www.ford-trucks.com/forums/forum122/
4570A
New Member Introductions
Jun 3, 2019 05:33 PM
iamhoss89
Jan 20, 2009 07:38 PM
JSchulz481
Aug 3, 2008 02:46 AM
kirkweston
Nov 12, 2007 10:26 PM
william7
Jul 29, 2007 06:48 PM
