94 E250, 4.9L, OBD1, C6, rear only ABS. All gauges read perfect.
Have the van for about 7 years, runs great, no warning lites lit except "air bag" (has been lit for 2 years because of bad clock spring)
A few days ago a buzzer under the dash started beeping, 5 consecutive, even beeps and then a pause, the repeats itself.
Repeats itself 4 or 5 times, then stops for about 5 to 10 minutes, then then starts repeating itself for another 4 or 5 times, then stops again.
thats for the clock spring ..i had the same problem....if you let the air bag lite on long enough it starts to go to a buzzer...you must have ignored that for a while...
mine took 10,000 miles then i changed it ..i think its should start at the begining but im not sure but just replace the clock spring and it will go away or unplug the buzzer...
