2001 Explorer sport/FL
Old Jan 24, 2009 | 11:47 AM
Florida Gerry's Avatar
Florida Gerry
I have a problem with the driver door. The door will not unlock with either the key fob or the manual key. I took the inside panel off and found the rod that will allow unlocking (it has a small yellow plastic part attached). If I lift up on this rod the problem is resolved.
I also found a small broken spring inside the door. I am thinking this is what holds tension on the rod. I am unable to find where it would attach and if it could be done without taking to ford. HELP AS THIS IS MY WIFE'S VEHICLE. Thanks, Gerry
Old Jan 24, 2009 | 03:00 PM
Fomoko1's Avatar
Fomoko1
Hi and welcome to FTE Gerry.
Too bad about the problem with the Explorer driver door but help is here so post in the Explorer, Sport Trac, Mountaineer & Aviator forum: https://www.ford-trucks.com/forums/forum32/
Also be sure to visit your local FL chapter and meet some of the fine folks there too: https://www.ford-trucks.com/forums/forum116/
Old Jan 24, 2009 | 03:24 PM
Florida Gerry
FOMOKO, I clicked on the address you sent but could not find the answer. Gerry
Old Jan 24, 2009 | 03:33 PM
Fomoko1's Avatar
Fomoko1
I reposted your inquiry in the Explorer, Sport Trac, Mountaineer & Aviator forum: https://www.ford-trucks.com/forums/forum32/ and hopefully someone should chime in soon. Click on this link: https://www.ford-trucks.com/forums/s...19&postcount=1
While it may take a little time I`m sure you`ll get your needed info.
Old Jan 24, 2009 | 03:35 PM
Florida Gerry
Ohhh, ok i was looking for a reply. Did not realize i had to re-post. Will do that now. Thanks, gerry
Old Jan 24, 2009 | 03:44 PM
Fomoko1's Avatar
Fomoko1
I`ve done it for you, hope you get a reply soon.
Old Jan 24, 2009 | 03:47 PM
Florida Gerry
Fomoko1, i really appreciate you doing that for me. I tried to copy and paste, but was unable to do it.
Again thank you, gerry
Old Jan 24, 2009 | 03:49 PM
Fomoko1's Avatar
Fomoko1
You are welcome, see you in the forums!
Old Jan 25, 2009 | 04:56 PM
Fomoko1's Avatar
Fomoko1
Hi Gerry, since I re posted your question for you in the Explorer, Sport Trac, Mountaineer & Aviator forum you won`t get reply notifications till you yourself reply to that thread.
To find it click this link: https://www.ford-trucks.com/forums/8...ml#post7053394
Greenhead99
New Member Introductions
Nov 19, 2014 11:53 PM
jabro
Dec 14, 2009 11:19 AM
peobus
Feb 15, 2008 04:18 PM
trucks967
Dec 27, 2007 01:35 PM
