Fuel system mod
Check this out there are 2 parts to this. I am wondering has anyone here done the mod to the fuel filter Bowl and the plugs on the heads? Does this do anything for more hp or just make the fuel gauge drop quicker?
If you want to remove the screens from inside the tank, do it this way Welcome to guzzle's In-tank Hutch Mod Web Page
If you drive your truck enough, there's a good chance something will end up in your tank. We put an inline filter between the tank and pump to keep from sucking anything into the pump.
For example, the first video: he calls that white thing inside the SD tank a filter. That is in fact the mixing chamber. He says it's a restriction to have in the tank. It's not. There is a design flaw with the mixing chamber that allows air to enter the fuel lines when the tank drops below 1/4. This is the reason people remove it, to fix the design flaw and get rid of the air, not for added flow. He also says the plunger in the fuel bowl is a restriction. It's not, removing the plunger has zero effect. The bowl and filter setup is a restriction on really high HP trucks, even if you remove the plunger. For stock or mild injectored trucks, the fuel bowl still flows enough fuel. How do I know? My fuel pressure gauge is installed on the regulator, which is at the fuel return line. So if the bowl was that much of a restriction, I would be losing pressure at WOT, and I would see it register at the gauge since it's mounted behind all the "restrictions".
In the second video, he's drilling out the fuel rail drain plug. That's all it is, a drain plug. If that plug were actually in the way and causing a restriction, high HP guys would have done this a long time ago. Lott and Zane have the quickest and fastest PSD's in the country, and neither one of them did this mod.
On most forums, the guy in the videos is a joke. Don't bother wasting your time. Ask questions here, and we'll set you straight.
