Sponsored by: Real Truck
Rear end rebuild
Old Jan 23, 2009 | 10:45 PM
Hitch03's Avatar
Hitch03
Rear end rebuild
I have a 03 f350 with a dana 80. The rear end needs to be rebuilt. Does anyone on here have a good write up how to do it?
Old Jan 23, 2009 | 11:19 PM
BMWM1's Avatar
BMWM1
Good luck youll need it!!!! Id go for a reman if it were me either way its going to be a lot of work
Old Jan 24, 2009 | 11:05 AM
Hitch03's Avatar
Hitch03
Do you recomend a place for reman
Old Jan 24, 2009 | 12:05 PM
ReAX's Avatar
ReAX
IF you need a write up, it's going to be best not to do it yourself or at least find someone who's done the job before (and has the tools) to help you. It's not particularly hard, but if you miss place a shim or change the gears, there are some critical measurements to make sure it's quiet when your done.
Depending on your local shops, you can probably have new bearing, seals and gears installed in your housing for under $1000.
BENG0924
Apr 7, 2008 07:27 AM
4ced air lightning
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 4, 2007 09:41 PM
RAMMU
Aug 28, 2006 05:18 PM
SUBARUTECH
Aug 23, 2005 09:49 AM
rebuild03
Sep 21, 2004 01:55 PM
