Sponsored by: Auxito
97-98 PCM Flash????
Old Jan 23, 2009 | 05:43 PM
jimbo8's Avatar
jimbo8
97-98 PCM Flash????
Does anybody know anything about having the PCM flashed on a 1997 4.6 Ext cab 4x4 to correct detonation problems? If so, would a dealer still be able to do it? My truck runs good and is well maintained but I have detonation or"spark knock" almost all the time under accelleration, but mostly during cold weather. The MAF is clean, good plugs & wires, new fuel filter, clean EGR ports. Still has soriginal O2 sensors with 132K miles on it.
Old Jan 23, 2009 | 06:44 PM
torkum's Avatar
torkum
Have you tried mid grade fuel?
Old Jan 23, 2009 | 06:55 PM
jimbo8's Avatar
jimbo8
Yes. It has helped some at times but is not consistent. I don't want to consider that a fix even if it did help because the truck is supposed to run on reg. unleaded.
Old Jan 24, 2009 | 07:36 AM
Ron W.'s Avatar
Ron W.
Still has original O2 sensors with 132K miles on it.
I'm not a tech but it coild be time to change those.
Old Jan 24, 2009 | 07:58 AM
chaser1602's Avatar
chaser1602
Why dont you take a look at the knock sensor first????? It might be cheaper than THROWING PARTS AT IT
Old Jan 24, 2009 | 09:06 AM
DarrinBC's Avatar
DarrinBC
Have you cleaned your MAF? That might help. A lot of auto parts store carry MAF cleaner spray now and you can do it yourself easily. If you have questions about where, what or how just ask.
Darrin
bcboy4ca
Jun 7, 2014 08:47 AM
muddyford911
2004 - 2008 F150
Jun 30, 2012 10:15 PM
mooneyman9
1997 - 2003 F150
Dec 29, 2005 07:48 AM
Jimbo302
3.8 & 4.2L V6
19
Dec 20, 2005 02:28 PM
canuckeh
Modular V8 (4.6L, 5.4L)
Nov 14, 2004 01:28 PM
