E40D "clunks"
Old Jan 23, 2009 | 12:18 PM
crazycobra1969's Avatar
crazycobra1969
E40D "clunks"
I have a 1995 F-250 4x4 5.8 liter with a E40D tranny I have just finished rebuilding it i saved it from the junk yard .I have been driveing it for a week and its been shifting smooth till yesterday it "clunks" when it shifts and when i hold the brake and shift from drive to reverse. I changed the column the OD button flashes when you push it and I changed the cluster yesterday but I am out of ideas i dont want to replace the tranny because i am 20 with a wife and set of twin and dont have time so any input would be greatly Appreciated thank you
Old Jan 23, 2009 | 12:32 PM
ech0sh4y's Avatar
ech0sh4y
Possibly a u-joint problem? lay under your truck and wiggle the drive shaft up/down/left/right there shouldn't be much play if any.
Old Jan 23, 2009 | 12:42 PM
crazycobra1969
I was thinking about that but would it do that when it shifts and i replace the rear ones
Old Jan 23, 2009 | 01:55 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
When the u-joint between the driveshaft and rear axle on my '94 F250 went out it did exactly what you describe. My buddy and I thought I had a transfer case problem. He was laying under the truck and I put it in gear and and the vibration would travel all the way up to the transfer case! Check those u-joints out and good luck!
