Sponsored by: Innova
installing a code alarm ca-530 into a 97
Old Jan 23, 2009 | 11:02 AM
swavet22's Avatar
swavet22
I received a code alarm CA-530 for Christmas and I'm looking for a easy to understand installation instruction. any help will be appreciated
Old Jan 23, 2009 | 02:48 PM
ReAX's Avatar
ReAX
1997 Ford F Series Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Blue/Green Ignition Switch Harness
Ignition 2 Red/Black Ignition Switch Harness (Heat)
Ignition 3 Black/Green Ignition Switch Harness (AC)
Accessory Gray/Yellow Ignition Switch Harness (Blower Motor)
Tach Blue/Green Multi Coil or White/Pink PCM Passenger's Wheel Well
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Light Green Brake Switch
Parking Lights Brown Behind Fuse Panel in Harness or Driver's Kick Panel
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple(-) Driver's Kick Panel
Door Trigger Black/Light Blue(+) On Driver's Dash below Instrument Cluster
Door Lock Pink/Yellow High Driver's Dash Negative Trigger w/Keyless Entry
Door Unlock Pink/Light Green Reverse Polarity w/o Keyless Entry
Horn Wire Dark Blue (-) Steering Column
I can help, but I don't have the instructions. There is quite a bit of good info here on the older model codealarms. Ford Remote Starter and Alarm Installation
bcrab
2004 - 2008 F150
Mar 4, 2008 01:23 PM
Schuebo
1997 - 2003 F150
Feb 28, 2006 12:04 AM
