Hey guys, I changed brakes on my Navi yesterday. All around new pads and turned the rotors. Routine job no biggie. Well now when you hit the breaks sometimes the pedal pulses like you are sliding on ice. And suggestions on what the problem could be? Thanks
Did you spray the rotors down with brake cleaner? If not, any grease, oil, or brake fluid on them will cause that wheel to lock-up while braking. That could be why your ABS is kicking in.
how does one 'clean' an ABS sensor? break clean? a simple wipe with a rag?
Yes that will do it. Just be a bit careful when wiping because they are magnetic and fine metal particle will be stuck there. They're kind of particles that like to get under your skin and cause pain for days every time you press something.
Thanks you, that's just what I did and now the light has been off since yesterday afternoon.
