Shudder -- ignition?
Old Aug 24, 2009 | 10:06 AM
ebraunusa's Avatar
ebraunusa
I am experiencing a shudder on my 98 4.6 expedition with 133K miles. Over the year, my gas mileage has dropped to 12-13mpg. Now I have the shudder. About a month ago, I had a check engine light on and found I had antifreeze in plug 6. I fixed that and the shudder is still here. The ignition has never been replaced.
Question. Should the plugs and wires be replaced? How about the coils? Do you use aftermarkets?
I was looking at FORD SOS Coils and it looks like the wires and coils are part of the same. Is that true? http://www.performancedistributors.com/soscoils.htm
How hard of a job is this?
Thanks!
Old Aug 24, 2009 | 11:39 AM
alloro's Avatar
alloro
At 133K have the plugs ever been changed?
In 98, I thought the 4.6 still had coil packs and spark plug wires? The link you provided shows a COP which is on all 5.4 engines and later year 4.6 motors. Can you confirm if your's has spark plug wires or not?
Old Aug 24, 2009 | 11:52 AM
ebraunusa's Avatar
ebraunusa
The plugs have not been changed and are the originals.
I pulled plug #6 and the tip looked gray. I believe it has just wires. When I pulled the wire, it had a 6" boot and I followed the wire to a pack.
How would I tell if it has coils?
Old Aug 24, 2009 | 12:04 PM
alloro's Avatar
alloro
According to the maintenance schedule, the plugs are supposed to be changed at 100K miles, so you're overdue with those. I would first change the plugs and see if the problem goes away, before wasting money on others problems that might not exist.
Old Aug 25, 2009 | 09:02 AM
ebraunusa's Avatar
ebraunusa
What brand of plugs?
Okay, will change the plugs. What brand of plugs? Motorcraft? Is there different lines and will one give me better performance and MPG?
Old Aug 25, 2009 | 10:27 AM
alloro's Avatar
alloro
Just use the original Motorcraft plugs, nothing else works better or improves performance/gas mileage.
Old Aug 26, 2009 | 08:32 AM
ebraunusa's Avatar
ebraunusa
Resolved
I replaced the plugs last night with Motorcrafts. The plugs that were in there were AutoLites and they must have be in there before I bought it at 60,000.
Anyways, the truck ran very smooth.
Thanks for the advice on starting with the plugs and seeing what happens.
Old Aug 26, 2009 | 02:08 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
[quote=ebraunusa;7862152]I am experiencing a shudder on my 98 4.6 expedition with 133K miles. Over the year, my gas mileage has dropped to 12-13mpg. Now I have the shudder. About a month ago, I had a check engine light on and found I had antifreeze in plug 6. I fixed that and the shudder is still here. The ignition has never been replaced.
We show that your model Expedition utilizes 2 coil packs-NOT COP's.
Please see what you need at:
http://www.performancedistributors.com/97f150.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Fordman49F1
2004 - 2008 F150
Jan 22, 2013 12:55 PM
quaddriver
20
Nov 1, 2011 02:24 PM
movieman387
1997 - 2003 F150
Aug 18, 2008 04:03 PM
RxWarrior
Apr 29, 2007 10:36 AM
