problems
Old Jan 24, 2009 | 09:09 PM
mstngmikegt's Avatar
mstngmikegt
Originally Posted by rockin300
i took the truck down the road and it sputered a little until i mashed on the gas after that it idled and ran right
Glad to hear it...keep using ISO-heet for the rest of the winter, as mentioned before don't let it get too low if possible and try to always buy your fuel at the same trusted place. Rest of the tune up related stuff, including fuel filter, would be a good idea to look at too but may be able to wait until warmer weather.
I would still strongly recommend having the alternator tested, either on or off the truck. If not addressed now, will most likely cause you bigger problems with your truck when you need it the most. Based on what you spent on it, the alt should have a great warranty on it, probably lifetime. Even brand new and thoroughly remanufactured parts still can and do go bad. Make sure you have a good one.
Old Jan 25, 2009 | 09:59 AM
rockin300's Avatar
rockin300
i am glad to be a senior user,i will get the alt tested,my truck still sputers a little but its good enough to drive
Dan92
Dec 10, 2010 04:19 PM
fordman49
Nov 9, 2009 10:25 PM
bansheeduner
Jan 9, 2008 10:42 AM
fordman363
Apr 5, 2006 09:25 AM
