leaky manifolds.
Old Jan 22, 2009 | 11:31 AM
caleb90's Avatar
caleb90
Temporarily Deactivated
leaky manifolds.
the 97-03 f150 were prone to leaky manifolds,i was wondering if our trucks have the same problem?also does any body have the part # for the o rings,that ill need to rplace when i do my up pipes.thanks
Old Jan 22, 2009 | 01:16 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Yes, the 99-03 7.3 PSD is known to eventually have leaking up-pipes (these connect the exhaust manifolds to the turbo collector "baby's butt"). If you get the bellowed up-pipes (available HERE from ITPDiesel) you'll get everything you need and probably never have to do them again.
Old Jan 22, 2009 | 02:57 PM
sneak's Avatar
sneak
I've got another question, has anyone had soot coming from around one of the exhaust ports between the manifolds and the heads? Mine does and I'm planning to do all of the pre-turbo exhaust in the next two years with new manifolds and the bellowed up pipe kit.
Old Jan 22, 2009 | 04:50 PM
caleb90's Avatar
caleb90
i no the up pipes are prone to leaking,im changing mine up pipes next weekend with the bellowed ones.but i was wondering if the manifolds that bolt to the side of the head are prone to leak also?
Old Jan 22, 2009 | 05:02 PM
ron's power stroke's Avatar
ron's power stroke
the only leak we hear most about is where the exhaust back pressure sensor (EBPS) tube goes into the head..its at the front of the manifold passenger side..
