5w20 vs 5w30
5w20 vs 5w30
Its time for my first oil change (since ive owned it) in my 2000 excursion (v-10). I went in to oriely's and asked what oil was recomended for this engine. They guy checked the computer and said it recomended 5w20 sythetic. I have NEVER used 5w20 in anything I have owned. I do use sythetic however. My excursion has 150,000 miles on it and runs great. I bought the 5w20 because they said that is what it calls for. But now I am having second thoughts. Should this be ok?
Thanks in advance
Thanks in advance
on
It's exactly what you should be using, 5w20 is what is specified by ford for the modular engines. 5w30 is okay as well since that is what ford originally specified, but if you live in a really cold climate then it's safer to stick with the 5w20 due to the smaller tolerances of the modular engines.
on
http://www.motorcraftservice.com/?li.../00hdwog3e.pdf
If you go to page 207 you'll see it specifies 5w-30.
Looks like I'm mistaken, I could of sworn they specified 5w20 in the V10s. Here's a link to the owners manual:
I believe its stamped 5w30. However, the parts store gave the recommendation based off the bulletin saying ford now recommends 5w20. I am sure with the cold weather 5w20 will be fine for now and I can change back to 5w30 at the next oil change
Similar discussion a couple weeks ago.
https://www.ford-trucks.com/forums/1...motor-oil.html
Conclusion: Doesn't much matter which you use.... Either one is adequate. Pick your choice and drive.
