E-Brake Bracket
Old Jan 21, 2009 | 09:12 PM
BushyTea's Avatar
BushyTea
E-Brake Bracket
On my 66 F-100 I have the pull handle e-brake that bolts to the underside of the dash. You pull the handle which pulls the cable and then that is suppose to pull the 2 rear cables to engage the e-brake.
Well the part that joins the 1 cable to the 2 rear cables was just rigged up and I had to remove that to replace the 2 rear cables that were seized.
What parts are needed to join the 3 cables together?
Thanks,
Mike
Old Jan 21, 2009 | 11:19 PM
jhooch's Avatar
jhooch
The cable from under the dash leads to a large spring loaded lever that pivots on the frame (may be on a frame crossmember), there is then a single cable I believe which runs to a small piece which has the single cable in the middle and two cables running off the outside, there is then two little connector pieces wich connect those two cables to the rear brake cables. Kind of hard to explain but I can picture it perfectly in my head....almost. I probably have most of the pieces laying around here.
Old Jan 22, 2009 | 07:06 AM
Bill W's Avatar
Bill W
If jhooch dosen't have the parts.... I do. just PM me if you want them.
Old Jan 22, 2009 | 11:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BushyTea
On my 66 F-100 I have the pull handle e-brake that bolts to the underside of the dash. You pull the handle which pulls the cable and then that is suppose to pull the 2 rear cables to engage the e-brake. Well the part that joins the 1 cable to the 2 rear cables was just rigged up and I had to remove that to replace the 2 rear cables that were seized.
What parts are needed to join the 3 cables together? Thanks, Mike
1966 F100 2WD 129" Wheelbase Styleside Pickup
Front parking brake cable attaches to C5TZ2A605A .. Parking Brake Equalizer Lever.
This lever bolts to C5TZ2631A .. Parking Brake Equalizer Bracket, which bolts to crossmember.
B7A2628A .. E-Brake Threaded Adjustment Rod -attaches to parking brake equalizer lever, then attaches to C3UZ2A602A .. Rear Brake Equalizer.
2) C5TZ2A793A .. Short (14") Parking Brake Cables attach to rear brake equalizer.
2) B7C2790A .. Clip-attaches short parking brake cables to right/left rear brake cables.
Tightening/loosening the adjustment rod, adjusts the whole shebang.
The entire parking brake cable system is illustrated here:
1964/72 Fortwod Truck Parts Catalog / Illustration Section 26, Page 9.
This catalog is available from hipoparts.com on a CD. $22.00 + shipping.
All these parts are obsolete.
NOS (New Old Stock) genuine Ford parts:
All I could find were the two short brake cables (C5TZ2A793A) and one of the clips (B7C2790A)
Green Sales Co. in Cincinnati OH has them: 800-543-4959
Old Jan 24, 2009 | 10:38 PM
BushyTea's Avatar
BushyTea
Thanks, thats what I was afraid of NumberDummy.
PM was sent so hopefully I can get my truck on the road soon.
Thanks guys!
Old Jan 29, 2009 | 11:38 PM
BushyTea's Avatar
BushyTea
Hey Bill, just wanted to give you a heads up I sent you back that PM.
Old Jan 30, 2009 | 01:37 PM
Bill W's Avatar
Bill W
got it, sent you back one just not. sorry wednesday morning i was in a crash, totaled my work truck, a real bummer! women drivers
s.squared-39
Aug 2, 2016 11:36 PM
s.squared-39
Aug 2, 2016 02:13 PM
broke33
Jun 7, 2016 06:23 PM
taz6131965
Nov 30, 2015 01:23 PM
aldrowsboy
Aug 14, 2013 11:06 PM
