hey Yall! I have finally come to the point of reality. I cant keep my idi forever as a daily driver. I bought a 99 f350 ps c/c drw. The price was right and I couldnt pass it up.
Since we last talked I have pulled the motor down because of the water in oil problem. The oil cooler o-rings were bad!!!! But to make matters even worse, as i was cleaning the block up to install the heads. I knowticed a piston looked like it had a crack. After cleaning all of the pistons I have 5 that are cracked. The only way i know that this can happen is useing either or starting fluid. I havnt used it on this motor and refuse to use on any motor with glowplugs. I will be pulling the pistions out of another motor with a bent crank. I hope they are ok. If yall have any suggestions of things i should do please let me know. Thanks for all yalls help!!!
I needed something a lil newer to truck the babys around. I will never let my idi go!!!! I wish i could by one brand new!!! if so i would have done that.
