General Automotive Discussion
Pertronics points replacement unit
Old Jan 21, 2009 | 07:36 PM
Dialtone's Avatar
Dialtone
I have a classic 68 t-bird 429ci I am rebuilding and was wondering if anyone had any experience with these or some of the "other" points replacement units.
I am leaning to the pertronix units from the standpoint of not needing some other external box to do the points replacement.
Any comments?
Old Jan 22, 2009 | 03:29 AM
rebocardo's Avatar
rebocardo
I just did it for a boat with two V-8 318s, very easy as long as you get the correct boxes the first time
If you search the 67-72 forums and Off Road forums you will see many people have done the conversions. You can always keep the points and cond. in the glove box as a back up, but, the Pertronix rarely fail.
I think it is well worth the money, usually $80-$120.
Old Jan 22, 2009 | 07:10 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you can find one, use the pertronix ignitor I
i don't care for the "new and improved ignitor II"
also, leave the resistor wire in place. they tell you to remove it, but the pertronix unit works better on 8 volts than it does on 12 volts. i have seen 4 fail when 12 volts was put to them. but on 8 volts, there are some out that i put in over 25 years ago, and still going strong.
Old Jan 22, 2009 | 09:08 AM
jimandmandy's Avatar
jimandmandy
They tend to die suddenly when they go, just like on some of the older GM factory units. When you put the electronics inside the distributor, heat is a problem.
Take a look at the Crane Cams unit. It seems to hold up better, and includes a built-in adjustable rev limiter.
Jim
Old Jan 22, 2009 | 09:27 AM
tjc transport
i ain't rite
that is only a problem when you put 12 volts to it.
that is why i said to leave the resister wire hooked up.
Old Jan 22, 2009 | 06:23 PM
galaxie641's Avatar
galaxie641
I put one on my '64 352 and like it, but I also haven't put a lot of miles on it yet.
Old Jan 22, 2009 | 08:15 PM
Dialtone's Avatar
Dialtone
Curious why you say this? I was reading (somewhere) that the ignitor I could self destruct if the ignition switch was left on too long without the engine running, but the ignitor II series fixed that problem.
Old Jan 22, 2009 | 08:32 PM
tjc transport
i ain't rite
ignitors I units i put in over 25 years ago are still running.
ignitor II units i tried using never lasted more than 2 months in my 7 litre. after 4 of them burnt out, i went back to the original ignitor I, and no more problems.
that was 8 years ago now. and i know 3 other people that have tried them since, and everyone has died within a few months. when they put the ignitor I in, they never had a problem again, just like me.
i recommend to everyone to leave the resistor wire or ballast resister on, and run a stock coil. there is no reason to waste money on the pertronix coil.
Old Jan 23, 2009 | 07:52 PM
rebocardo's Avatar
rebocardo
I agree. You can buy for $12-$18 a coil with the resistor built in at Advance. That is what I did for one of my older Fords when I wanted to eliminate the wire because it was so hard to get to behind the dash.
